I am a novice at building Lans but have a lot of computer experience. I have a 4 port gigabit Lan using a router ( with DHCP enabled) and want to expand its capability so I can connect all of my gear to the internet. I have purchased switches and routers (with DHCP disabled) to set up the Lan but I am having difficulty getting it to work reliably. Following is what I want to do:
My device for internet connection is a cable modem.
I have an extensive hard wired house but need more connections in some locations thus switches are needed.
I have hooked up my 4 port Lan router and it works great as long as I only use the 4 ports to connect to other devices directly. If I hook up a swtich to the router to expand the number of ports beyond 4, I have great difficulty getting eveything to work. I can get pieces of it to work but not the whole thing. I tried the router with automatic IP addressing and also with fixed IP addressing using MACs to assign the various devices. Neither works very well.
Is there something I can read that will help me get this Lan setup and running properly? Any suggestions would be welcomed.
Patrick Thomas
Patrick Thomas
