If you have not finished it yet, and you will use Ubuntu - my advice is to use v.8.04 instead of the latest one v.8.10
I converted the PC in the living room from Windows XP to Ubuntu Desktop, and I am very happy with it. I will use it for movies, NAS and torrents from now on. It is not t all as compact as the pre-built NASes, but it can do everything, and much faster.
Why Ubuntu 8.04?
At first I installed Mythbuntu 8.10 - no sound, then tried Ubuntu 8.10 - again no sound and also could not set up the resolutions that the TV supports (1920x1080i and 1280x720p).
Then I found a lot of reports for broken sound in v.8.10 due using new sound architecture, PulseAudio. Then I installed Ubuntu 8.04, and everything works.
The current hardware is: GA-MA78GM-S2H + AMD X2 4800+, 4GB RAM, 320 + 750 GB disk drives, and Asus DVD writer. No discrete video card, using the HDMI output from the mainboard to the TV. It is also usable to browse the internet, however 32" TV is a bit small for that - I need to change the fonts to larger and use the firefox zoom feature to read the texts easy.
Both Windows XP (32 bit) and Ubuntu (32 bit) used 3GB of memory out of 4GB.
________
Porntube
Why Ubuntu 8.04?
________
Porntube
