Asus RT AC68U not that great?
Hi folks.
Just joined, bare with me plz!
I just picked up the Asus RT AC68U to replace my outgoing router. Note, the outgoing router is the WD N750 dual band.
The WD router worked well, but I noticed the signal dropping substantially when in my backyard, which is about 50 ft away--passing through some drywall and a brick exterior wall.
My internet connection is stable at 50/10 using Bell Canada.
A speedtest with the WD router yields a result of about 30mb/s (speedtest.net) with the 2.4ghz and about 43mb/s with the 5ghz band.
In comparison, the Asus RT AC68U yields a result of about 28mb/s with the 24ghz and 37mb/s with the 5ghz band. Note, both results kept all else constant with the only change being the router. The placement of the routers were the same, the same laptop and distance were also the same. Note, the distance for these tests were to my living which is about 25 ft away. Also, I live in a two story house and the router is located in the second floor, central in the house.
I was under the impression this router (not cheap!!) would give a result better than what I've noticed. The distance has increased somewhat, but the actual speed (according to speedtest.net) seems to be slower than my 2 yr old middle grade WD router. Also, I have a hard wired PC connected to the router which yields the full 50/10 result.
I have the latest firmware installed to date.
I was contemplating installing the Asus Merlin firmware for this router. Any ideas or suggestions? On Asus's website
http://www.asus.com/Networking/RTAC68U/ they claim the TurboQAM technology will enable it to be up to 3 times faster using N etc.... I understand the use of the word UP TO, but holyS*** that price just doesn't seem worth it. IF the only benefit I've noticed is a further WIFI reach, then I'm better off buying a used router and configure as another access point.
What are your thoughts?
I have not installed Merlin just as yet...
Thanks!
