joegreat
Hi,In comparison, the Asus RT AC68U yields a result of about 28mb/s with the 24ghz and 37mb/s with the 5ghz band. Note, both results kept all else constant with the only change being the router. The placement of the routers were the same, the same laptop and distance were also the same. Note, the distance for these tests were to my living which is about 25 ft away. Also, I live in a two story house and the router is located in the second floor, central in the house.
Do not forget to reset (delete!) the profile of the client computers/laptops/tablets/smartphones!
Only if you reconnect to the router with a new profile all the low-level parameters will be set correctly by the client.
For the 2.4 GHz WLAN do not forget to find the less busy channel and avoid 40 MHz settings (in crowded areas with many WLANs around).
Then retest and see...
With kind regards
Joe
