Buying Advise
I would think router if you are running bridge mode. You said your router is reporting a problem with DHCP.
You ISP should know when your DHCP renews?
Is this what I'm Looking for ?
If it is, Then since it Renews Every 6 Hours does that mean if it where the issue then the issue should occur every 6 hours?
EDIT: Also I'm In "Wireless router mode/ AiMesh Router mode (Default)"
Don't you have a real log? If it is every 6 hours then it may not be your problem. But I would look into why you are seeing an error on DHCP.
