ca.crt window/cell too small.
for those who have used several different brand wireless routers, which do you rate the highest?
  • TP-Link
    Votes: 0 0.0%
  • Netgear
    Votes: 0 0.0%
  • ASUS
    Votes: 4 100.0%
  • Total voters
    4
  • Poll closed .
aolone
I am using a VPN service and their ca.crt file contains 2 certificates, for a total of 4kb.
This file does not fit in the ca.crt cell provided by Merlin. Is there a way to make this cell bigger? Copy paste I can only see the middle of the second cell at the last visible line. If I make a OVPN file for upload it does not give any errors, but I can only see the middle of the second certificate as the last line again and the vpn will work for a couple of hours and then disconnect.
I think your file contains CA and Static key and they have their own box.
every files have "Limit: 3499 characters per field"
Unfortunately increasing the limit isn't as simple as increasing it in the HTML code. The whole firmware code need to be examined afterward to increase any internal buffers that would process it - there are quite a few throughout the firmware code. At this point I'd rather not chance it, the current limit is pretty good already.
Any favorite VPN service one can recommend?
n9nu GUI Window Zooming Issue - Minor Asuswrt-Merlin 2
