Can a WD my Book 4 TB be formated to EXT4 or EXT3?
If you are on Windows you can use easeus partition master to to ext file systems or a Linux live cd
Title says it all.
Yes, it can!
This answer says it all. :eek:
I have it on my Linux Homeserver with 2 partitions and EXT4 formated since long time.
Before you start doing the Linux formatting, I would suggest to update the Firmware of the WD myBook to the latest version to avoid any problems.
All you need is a small Linux machine to do the job!
  1. Either you use something like one of our ASUS routers (NOT recommended as it will take ages!!!), or
  2. you boot Linux (simpliest would be Ubuntu) on your PC, with attached WD myBook and you do the job.
On the internet (Google is your friend here) you will find plenty of How-To's on this topic! :rolleyes:
With kind regards
Joe :cool:
Thanks for the info. I will look for a Linux Live CD online, I did some searching and saw there are many Linux Live CD's. Any recommendations?
http://livecdlist.com/
Also my boot drives are mirrored and stripped so I can just remove them from the Cmos as a boot drive?
RT-AC68U is my router with Asuswrt-Merlin's latest firmware.
I'm running win7 64 on Asus P7P55D-E PRO quad at 2.8ghz with 4gigs
Thanks again
Ken
Yes, it can!
With kind regards
Joe :cool:
Thanks Joe for your help.
I have searched till I was blue in the face. I could not get a definitive answer on the WD myBook since it can not be separated from the case. I'm also hoping that I can use Merilyn spin-down on this drive?
I just set this up and did a firmware check and it was up to date. I want to do this with a Linux live cd or MiniTool Partition Wizard ?
Thanks again
Ken
Make sure that you know how Linux names its drives. sda will be your primary internal hard drive. If you have a second hard drive installed, it will be sdb, otherwise your external drive will be sdb. You don't want to wipe out your primary hard drive by mistake.
Also, plug in your external HD after Linux boots up. I had a situation a few years back where I booted from a CD with the external HD plugged in, and the kernel assigned the names backwards, naming internal #1 sda, external sdb, and internal #3 sdc. I ran mkfs.ext4 on sdc, thinking that it was the external one. :eek:
Spin down
Any ideas how the spin down will work for this drive, Western Digital does it from a utility in Widows. Is this hard coded in the unit ? Better to set before formatting? or Disable and use Merilyn's.
Thanks, I have one raid drive setup as my boot drive for windows and non raid one as a dumping ground, all ntfs.
Ill also need to see if there are any formatting options that might help for EXT4 on the router.
Personally, I hate Ubuntu due to the unique interface and Gnome 3.
There are graphical tools to format a drive but I find the command line eaier and more satisfying.
Linux Mint (any flavour) would be my advice.
Just got this Mybook 4TB drive yesterday. Connected to a 68R. Spin down works with Merlin just fine.
Is your drive re formated to EXT4 or stock NTFS? If it's stock NTFS and your spin down is set out of the box from WD to 30 minuets. You have to connect it to a PC and run the utility that's on the disk. You can set it to Never stop spinning and then see if Merlyns spin down will work.
Ken
Ken
NTFS.
I never used any WD software. Deleted it.
It is set to 300 seconds in Merlin and it works.
Same with a 2TB WD My Passport hard drive.
Both spin down as specified in Merlin.
NTFS.
Try this. Turn off Merlyns 300 sec spin down and see if your Mybook 4TB drive spins down after 30 minuets.
The My Book and My Passport are sleeping after 30min.
Thanks, I will disable my spin down via the WD utility and use Merlin's. I have to get this right before I format the drive to EXT4, not sure how WD utility will handle an unsupported format. you might want to get the utility from WD, there was a firmware update from WD for my drive, I also just purchased this drive this past week.
Ken
