Can a WD my Book 4 TB be formated to EXT4 or EXT3?
Log info look ok? plugged in the 4 TB usb3 drive after formatting ext4 and partition
I have not changed any thing yet in Merlin's just plugged in the drive.
Ken
May 26 15:41:37 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
May 26 15:41:37 kernel: xhci_hcd 0000:00:0b.0: WARN: short transfer on control ep
May 26 15:41:37 kernel: force burst = 0.
May 26 15:41:37 kernel: xhci_hcd 0000:00:0b.0: WARN no SS endpoint bMaxBurst
May 26 15:41:37 kernel: scsi1 : usb-storage 1-1:1.0
May 26 15:41:38 kernel: scsi 1:0:0:0: Direct-Access WD My Book 1230 1059 PQ: 0 ANSI: 6
May 26 15:41:38 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
May 26 15:41:38 kernel: scsi 1:0:0:1: Enclosure WD SES Device 1059 PQ: 0 ANSI: 6
May 26 15:41:38 kernel: scsi 1:0:0:1: Attached scsi generic sg1 type 13
May 26 15:41:38 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:39 kernel: sd 1:0:0:0: [sda] Spinning up disk....
May 26 15:41:39 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:40 kernel: .
May 26 15:41:40 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:41 kernel: .
May 26 15:41:41 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:42 kernel: .
May 26 15:41:42 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:43 kernel: .
May 26 15:41:43 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:44 kernel: .
May 26 15:41:44 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:45 kernel: .
May 26 15:41:45 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:46 kernel: .
May 26 15:41:46 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:47 kernel: .
May 26 15:41:47 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:48 kernel: .
May 26 15:41:48 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:50 kernel: .ready
May 26 15:41:50 kernel: sd 1:0:0:0: [sda] 976746240 4096-byte logical blocks: (4.00 TB/3.63 TiB)
May 26 15:41:50 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
May 26 15:41:50 kernel: sd 1:0:0:0: [sda] Write Protect is off
May 26 15:41:50 kernel: sd 1:0:0:0: [sda] Assuming drive cache: write through
May 26 15:41:50 kernel: sda: sda1
May 26 15:41:50 kernel: sd 1:0:0:0: [sda] Attached SCSI disk
May 26 15:41:51 hotplug[1344]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/sda1
May 26 15:41:51 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
May 26 15:41:52 rc_service: hotplug 1344:notify_rc restart_nasapps
May 26 15:41:52 iTunes: daemon is stopped
May 26 15:41:52 FTP Server: daemon is stopped
May 26 15:41:53 Samba Server: smb daemon is stopped
May 26 15:41:53 kernel: gro disabled
May 26 15:41:54 Timemachine: daemon is stopped
May 26 15:41:54 kernel: gro enabled with interval 2
May 26 15:41:55 Samba Server: daemon is started
