Can I disable rtac3200 smart connect
Clients won't balance, it will be up to each client to decide to which radio it will connect - most likely the one with the strongest signal.
Thanks I hope asus adds smart connect only for 5g. There's clients I never want on 2.4. It's also odd guest networks dont use smart connect.
T Smart Life Device Keeps Disconnecting Daily ASUS AC Routers & Adapters (Wi-Fi 5) 1
