Thanks sir for the information can you please guide me step by step because I don't know where to find the pointed fileLook for WebHistory.db in /jffs (I forgot the exact location). It's a sqlite database.
This may be useful Web History Reporting and Management (Traffic Analyzer/Aiprotection Monitor)I wonder if I am able to export a report for the web history if there's anyway to do that please guide me.
Regards.
Thank you I really appreciate what are you trying to help me with
There is a wealth of information here RMerlin Wiki and includes examples of implementing scripts on the router.Thank you I really appreciate what are you trying to help me with
I am actually beginner in network world and I want to accomplish this goal but I need more details now how I can enable
- the .sh is it related to.ssh access?
- where should I place the codes?
- Should I being connected through Ethernet to avoid any failure or no need for Ethernet?
dos2unix /jffs/scripts/this_script.sh
chmod a+rx /jffs/scripts/this_script.sh
nvram set jffs2_scripts="1"
nvram commit
sh /jffs/scripts/this_script.sh
The script was originally hosted on Pastebin, but was moved to GitHub, and the Pastebin link now refers toBy the way this link isn't working: https://pastebin.com/1Aap745G it was in your post.
Basics for creating/exploiting scripts.
1. Enable SSH access to router via the GUI
Administration->System TAB then Click 'Enable SSH=LAN only'2. If you are using a Windows device then install WinSCP to create/edit the script file on the router.
I posted a mini-tutorial of getting a script onto the router via WinSCP:3. As per the Wiki, ensure your script is executable
Using WinSCP to create scripts/files on Asus Router
or SSH into the router then use the router's nano editor.
SSH to the router using your preferred SSH Client (Xshell6,MobaXterm or PuTTY etc.) and issue4. Ensure that execution of scripts is enabled - either via the GUI
Code:dos2unix /jffs/scripts/this_script.sh chmod a+rx /jffs/scripts/this_script.sh
Adminstration->System TAB then Click 'Enable JFFS custom scripts and configs=YES'5. If you are logged on to the Routers SSH console you can now test the script
or from the command line
Code:nvram set jffs2_scripts="1" nvram commit
Code:sh /jffs/scripts/this_script.sh
here
here
here
I don't know how much more simpler those steps can be written out.I am sorry I am asking so much but I need to because the router is new and I don't want to mess it.
Did you follow my mini-tutorial Using WinSCP to create scripts/files on Asus Router ? - is it too difficult to understand how to navigate thru' the file system on the router, then copy'n'paste the code into the appropriate script file?I have opened WinSCP I entered the host as the IP of the router and username as the username that I am logging in to Asus GUI same thing for password after I clicked connect I am just in /tmp/home/root and it's empty now I am confusing about what I have to do?
If the scripting is too difficult, then you will need to use the command line to manually run SQL queries using the sqlite3 utility (if not already installed) from Entware - assuming you know the SQL syntax etc.
I believe it's too easy on you brother but I am not at the same level of yours, I am a beginner trying to learn and understand so it's normal to have couple of dark points in front of me because it's new thing on me so don't measure things depends on your knowledge.I don't know how much more simpler those steps can be written out.
Yes I have watched it but is it normal to find no even 1 file inside it? is the normal case of this place is to be empty? this is what stopped me as I am thinking if I am the wrong place or what... so if it's normal tell me so I can complete the steps.
Directories '/jffs/configs' and '/jffs/scripts' are normally empty by default.
You need to manually create the custom scripts in '/jffs/scripts' as per the Wiki - that is the raison d'être for using the RMerlin firmware rather than the stock firmware.
Yea, sorry wasn't trying to offend, I was looking for away I could try and explain it in simpler measures, but I couldn't find any, that was all I meant.I believe it's too easy on you brother but I am not at the same level of yours, I am a beginner trying to learn and understand so it's normal to have couple of dark points in front of me because it's new thing on me so don't measure things depends on your knowledge.
tmp/home/root is the base directory. you would have to branch out to other directories, common method would be typing,
cd /jffs/scripts
or
cd /jffs/
or
cd /jffs/configs
then you will see more of that directory by simply typing
ls into the command line.
if the directories don't exist you could make them by typing
mkdir /jffs
mkdir /jffs/scripts
mkdir /jffs/configs
(the directories should exist if you have jffs enabled)
and then you would be able to use the cd command option above.
these are the base areas that all scripts are read from.
9644 Entware sqlite not availble
I am afraid from upgrading because now everything is stable so I am trying fix things in the current available solutionsfirst I would update to recent 384.13, easier for all than with older firmwares.
Welcome To SNBForums
