Can I export report from web history on 384.11 - Asus RT-88U
As I am in the UK, the dates you have quoted would to me be the 2nd,6th,7th August and 5th August, not 8th February, 8th July,8th August and 8th May.
The dates are showing like that in loading case:
2019-08-04
2019-08-05
2019-08-02
2019-08-03
2019-08-06
2019-08-07
but when the process finish only
2019-08-06
2019-08-07
Appeared...!
it's pretty weird behavior.
Although not all utilities are available on the router, I suggest you review Unix commands by Category to see for which purpose you would use awk/sed and grep etc.
NOTE: Weirdly, grep is missing in the above? but it does appear in this more comprehensive list List ofUnix commands
So for example rather than use the script to perform the filtering you can use the Unix utilities
e.g. Use 'grep' to filter out any Web History records that contain the string 'google', and use the 'head' utility to only print the first 10 matching results:
./WebHistory_Report.sh nofilter noscript | grep google | head -n 10
(WebHistory_Report.sh): 14364 v1.14 Web History starting.....
2019-01-31 13:43:11|1548942191|58:C5:CB:05:5A:4B|android.clients.google.com
2019-01-31 16:44:49|1548953089|58:C5:CB:05:5A:4B|inbox.google.com
2019-01-31 16:31:37|1548952297|58:C5:CB:05:5A:4B|www.google.com
2019-01-31 16:43:07|1548952987|58:C5:CB:05:5A:4B|www.googleapis.com
2019-01-31 16:45:41|1548953141|58:C5:CB:05:5A:4B|clients4.google.com
2019-01-31 16:44:48|1548953088|58:C5:CB:05:5A:4B|play.googleapis.com
2019-08-07 08:27:20|1565166440|54:60:09:0A:17:F4|tools.google.com
2019-01-31 16:37:39|1548952659|58:C5:CB:05:5A:4B|safebrowsing.googleapis.com
2019-06-21 22:48:29|1561157309|48:45:20:D7:A6:22|clientservices.googleapis.com
2019-06-21 22:48:29|1561157309|48:45:20:D7:A6:22|accounts.google.com
This example adds an additional filter to the above matching records and eliminates any 'google' records that contain 'android'
./WebHistory_Report.sh nofilter noscript | grep google | grep -v android | head -n 10
(WebHistory_Report.sh): 25585 v1.14 Web History starting.....
2019-06-22 07:31:55|1561188715|48:45:20:D7:A6:22|www.googleapis.com
This example adds a further filter that eliminates any of the above matching records that occurred on the 31st day of any month in 2019:
./WebHistory_Report.sh nofilter noscript | grep google | grep -v android | grep -vE "2019-..-31" | head -n 10
(WebHistory_Report.sh): 22111 v1.14 Web History starting.....
2019-06-19 09:36:24|1560936984|48:45:20:D7:A6:22|www.google.co.uk
2019-06-21 22:48:39|1561157319|48:45:20:D7:A6:22|clients2.google.com
2019-06-21 23:04:34|1561158274|48:45:20:D7:A6:22|safebrowsing.googleapis.com
2019-06-22 07:32:30|1561188750|48:45:20:D7:A6:22|update.googleapis.com
2019-05-10 08:52:03|1557478323|48:45:20:D7:A6:22|storage.googleapis.com
2019-06-22 07:52:53|1561189973|48:45:20:D7:A6:22|pagead2.googlesyndication.com
Hopfully you can see that the use of the utilities (in this case 'grep') can provide very complex filtering.
Thank you so much for well explanation.
2019-08-04
2019-08-05
2019-08-02
2019-08-03
2019-08-06
2019-08-07
2019-08-06
2019-08-07
Appeared...!
I am still confused at what issue(s) you are reporting.
1. You originally reported you cannot print records for the month of July.
and now
2. Only 2 records for August are retrieved, rather than 6 records?
For issue 2. - if you specify the 'report=' directive, does the resulting .csv file contain only 2 records rather than the expected 6 records?
and now
About the first issue yes still cannot get the information of previous month even with grep I tried:
./WebHistory_Report.sh noscript nofilter | grep 2017-07-01 | head
but this return nothing.
The other problem is that when I type the following:
in the moment that the results are loading I see different days in the results but when the process finish and the list is read I can't see those days anymore except 6 and 7 for some reason I don't know why if you didn't understand tomorrow I can record a video for you.
Perhaps there are no database records for 1st July 2017
I suggest you try
./WebHistory_Report.sh noscript nofilter | grep 2019 | grep 07 | head
to see if there are any records containing both the strings '2019' and '07'
I suggest you try
Thanks I'll try this out after couple of days and back to you with the results.
