I don’t have a tri -band router mate.The router should always be the most capable device as it's settings are propagated to the nodes. As your router is dual band, your nodes will get a dual band configuration. Make one of your tri band routers the router. Move your existing router to be a node and it will work best if it can have a wired backhaul as there will be a performance hit to use a dual band router with a wireless backhaul
I don’t know what pgershon means.You are also not member pgershon.
OE
I already did and deleted my message in this thread.Please, post and reply to your own thread here:
Connection drops in mesh system
Hi folks, I've spent some time trying to solve it but I could not. I'm desperate for your help. I have Asus ZenWifi XD4 Plus (2-pack) and I did; 1) put Virgin HUB3 ISP modem/hub combo on bridge mode 2) assign XD4 Plus as a main router 3) connect mesh node via ethernet backhaul It's been a...www.snbforums.com
Someone bumped an old thread, someone else replied to an old post, you replied to something not directed at you, etc.
Welcome To SNBForums
