The subject pretty much says it all.
I have Rogers 250/20 service and when I try any speed tests, my max is 200 down. It definitely appears to hit some type of limit. I do not have QOS turned on.
When I run the speed test connected directly to the modem I hit 320 down.
I am wondering if some setting is causing this or is this the fastest this router can handle?
(all tests performed hardwired)
Thanks in advance!
Thanks in advance!
