Cannot open the login page ( 192.168.1.1 )
Danielsen
Hi!
As title says I cannot open the login site on any browser, Opera, Chrome, FF (Deafult), Chrome and IE.
My internet works fine, i can browse the sites and be in here aswell. This problem is the result for a few hours at googeling. time to stop it now I think.
Here is my ipconfig /all list.
C:\Users\Alexis\>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Alexis-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) 82583V Gigabit Network Connection
   Physical Address. . . . . . . . . : 60-A4-4C-61-BE-81
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::9d81:6cca:b33d:8a5b%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.62(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 15. juni 2013 19:03:05
   Lease Expires . . . . . . . . . . : 16. juni 2013 19:03:04
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 257991756
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-1C-D0-5F-60-A4-4C-61-BE-81
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{6DEA958C-C923-4B80-88B0-2FD92EFEB660}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:3802:3a40:3f57:fec1(Preferred)
   Link-local IPv6 Address . . . . . : fe80::3802:3a40:3f57:fec1%11(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\Alexis>
FireFox error
The connection was reset
          The connection to the server was reset while the page was loading.
  The site could be temporarily unavailable or too busy. Try again in a few
    moments.
  If you are unable to load any pages, check your computer's network
    connection.
  If your computer or network is protected by a firewall or proxy, make sure
    that Firefox is permitted to access the Web.
Does anyone got any idea on what i can do ? or is only one hard reset the only choice ?
What do you see if you ping the router address? Cleared the browser cache?
Set the router address different from default one and did you try that as well?
Anything changed in your browser settings from default? Also reload f/w.
C:\Users\Alexis>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\Alexis>
Yes, cleared the caches a few times aswell with one ipconfig release, renew and flushdns.
Dunno how to change the deafult router address since i cannot log into it.
Nothing have changed in my browsers as far I know of.
Did you disable regular access and enable https? In that case the router will answer on port 8443 (https://192.168.1.1:8443).
Did you enable telnet? See if you can connect over telnet by using putty, kitty or Xshell.
I assume you are in router mode and not in AP or bridge mode?
Hmmm,
It must work when you updated f/w. After f/w upgrade this problem popped up?
Or can you remember since when this problem started?
If Merlin's suggestions do not solve the problem,
time to hit the reset button and fall back to default. And reflash f/w.
The https won't work either. Aswell with putty. Router mode, is that when i'm using that to connect to the router and then to the internet ? If that is, then yes.
Hmmm,
Guessing the reset button is up for grabs tonight then.
Think i've been into the settings a few times also after the FW upgrade. Cannot say for certain.
Did by chance you assign the same address to a modem or other device? Is it possible you are pinging a different device?
