pasha4ur
Hello.
Help me please.
My friends gave me the router and said that it periodically got hot and stopped working. They rebooted the router frequently.
I turned it on. But only the power and connected local or input port lights, where the wire was were lit. Except for network port No. 2. It doesn't react to cable. The Wi-Fi network did not appear and did not turn on the indicators. The computer reports that the local wire is not connected. Although I was able to get this address from the router to the computer once:
I tried resetting the router with combinations of buttons (reset and wps), but it doesn’t start blinking. No entry into recovery mode. Can't access or ping 192.168.1.1 (I configured my PC adaptor settings to 192.168.1.10)
Currently, when turned on, the router behaves like this:
1. All indicators flash 1 time.
2. Next, the power and connected port indicators light up.
When connecting this router to another similar working router by wan or lan port it shows port connection 1000, but the problematic router does not appear in the list of devices of the working router (fresh tomato).
I changed power supplies between routers. No changes.
Photos of the board are available here: https://drive.google.com/drive/folders/1FiyWW18lhVTwY85mdOb7tTY-wYefSVdz?usp=sharing . I saw no signs of destruction. Only moisture from thermal pads is visible.
Help me please.
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix. :
Link-local IPv6 Address . . . . . : fe80::f704:8826:695e:fb27%22
Autoconfiguration IPv4 Address. . : 169.254.207.26
Subnet Mask. . . . . . . . . . . : 255.255.0.0
Default Gateway. . . . . . . . . :
