ADarkDividedGem
I am using the RT-AC66U B1 with firmware version 386.1_2
I have enabled SSH via port 22 in the system settings
When I am connected via the 2Ghz wireless (not guest) connection I have no problems logging into the router over SSH using PuTTY:
When I try the same thing using the 5Ghz wireless connection PuTTY simply times out
In the system log it simply lists the attempt and that the connection timed out:
Does anyone know what I could be doing wrong or should I open up a bug on the asuswrt-merlin.ng GitHub page?Feb 16 13:13:18 dropbear[25274]: Child connection from 192.168.0.22:56297
Feb 16 13:13:39 dropbear[25274]: Exit before auth from <192.168.0.22:56297>: Error reading: Connection timed out
