Can't Change RT-AC86U password
Hello,
I have the exact same problem.... I know the password, just can't change it using the web-gui....
ASUS RT-AC86U asuswrt-merlin Firmware Version:386.7_2.
Can you enable SSH access in the GUI? If so try resetting the password using this method:
Hello,
I was able to change using
https://www.snbforums.com/threads/how-to-reset-encrypted-admin-password-via-ssh.77786/post-749920
answer. But after doing that I still couldn't change it in the web. I eventually took screenshots of the most critical areas and did a factory reset. That did solve the problem.
- - - edit to fix the link - - -
Does your password have more than 32 characters? Are they all alphanumeric, with no spaces, special characters, punctuation, or smiley faces?
Try entering your old password with 1 character less each time (until it works).
I have special characters in my password, which is 15 characters in length and it works without any problems.
Worked,
nvram set http_passwd=admin
nvram commit
Next time I want to change the password I will need to do it again like this
Worked,
nvram commit
that's what I found.
So I ended up doing a factory reset. Put back all my settings. Now I can change it via the GUI. So far twice.
Until one of the special characters creates an issue. Then you start a new thread asking what's wrong and how to fix. ;)
