Can't disable Samba share and drives not showing on GUI
usuario74
Owner of RT-AX86U. Merlin 386.5
After spending many days setting up my new router as I had my RT-AC3200.. I got to the last item I had to set: SAMBA shares.
I have a flash drive and a external hard drive both connected to the router but.. on the GUI on section Advanced_AiDisk_samba.asp
First issue: It is not showing the drives at the bottom of the page. Empty. Can't add any folders. I can add users. Strangely on Windows File explorer I can access folders (from both devices) being shared from the router.
Second issue: If I try to turn off the Enable share button to disable the shares. It will show spinning "Applying settings" and remain like that forever. If I refresh the page after ten minutes. The shares remain enabled.
I have searched the forum but couldn't find anyone with similar issues. I really don't want to start from scratch. It took me many hours to get to this point.
I have installed diversion, skynet, Yazfi and rtorrent. Like I had on my older router.
Any help?
Where can I find a log that could give any insight?
Thanks.
I see this on the log page in GUI when I try to disable share (without success):
Apr 18 14:13:44 rc_service: httpds 1808:notify_rc restart_ftpsamba;restart_dnsmasq
Apr 18 14:13:44 custom_script: Running /jffs/scripts/service-event (args: restart ftpsamba)
Apr 18 14:13:44 FTP_Server: daemon is stopped
Apr 18 14:13:44 wsdd2[13320]: Terminated received.
Apr 18 14:13:44 wsdd2[13320]: terminating.
Apr 18 14:13:44 Samba_Server: smb daemon is stopped
Apr 18 14:13:44 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Apr 18 14:13:44 Diversion: restarted Dnsmasq to apply settings
Apr 18 14:13:44 uiDivStats: dnsmasq has restarted, restarting taildns
Apr 18 14:13:45 Samba_Server: daemon is started
Apr 18 14:13:45 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
Apr 18 14:13:45 wsdd2[31331]: starting.
Apr 18 14:13:46 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Apr 18 14:13:46 Diversion: restarted Dnsmasq to apply settings
Apr 18 14:13:46 uiDivStats: dnsmasq has restarted, restarting taildns
Apr 18 14:13:49 admin: Started taildns from .
/var/log/log.nmbd
[2022/04/18 11:14:14,  0] nmbd/nmbd.c:861(nmbd_main)
  nmbd version 3.6.25 started.
  Copyright Andrew Tridgell and the Samba Team 1992-2011
[2022/04/18 11:14:20,  0] nmbd/nmbd.c:66(terminate)
  Got SIGTERM: going down...
[2022/04/18 11:14:22,  0] nmbd/nmbd.c:861(nmbd_main)
[2022/04/18 11:14:24,  0] nmbd/nmbd.c:66(terminate)
[2022/04/18 11:14:26,  0] nmbd/nmbd.c:861(nmbd_main)
[2022/04/18 11:14:59,  0] nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
  Samba name server RT-AX86U is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.1
[2022/04/18 13:52:56,  0] nmbd/nmbd.c:66(terminate)
[2022/04/18 13:52:57,  0] nmbd/nmbd.c:861(nmbd_main)
[2022/04/18 13:53:30,  0] nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
[2022/04/18 14:13:44,  0] nmbd/nmbd.c:66(terminate)
[2022/04/18 14:13:45,  0] nmbd/nmbd.c:861(nmbd_main)
[2022/04/18 14:14:18,  0] nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
SMB.CONF
Have to say I have never shared those folders. The system is automatically sharing all the root folders on the hard drive and the flash drive.
admin@RT-AX86U:/tmp/home/root# cat /etc/smb.conf
[global]
netbios name = RT-AX86U
server string = RT-AX86U
workgroup = WORKGROUP
username level = 20
unix charset = UTF8
display charset = UTF8
load printers = no
printing = bsd
printcap name = /dev/null
log file = /var/log/samba.log
log level = 0
max log size = 5
security = USER
guest ok = no
map to guest = Bad User
encrypt passwords = yes
pam password change = no
null passwords = yes
force directory mode = 0777
force create mode = 0777
max connections = 5
socket options = IPTOS_LOWDELAY TCP_NODELAY SO_KEEPALIVE
obey pam restrictions = no
use spnego = yes
client use spnego = no
disable spoolss = yes
host msdfs = no
strict allocate = no
wide links = no
bind interfaces only = yes
interfaces = lo br0 192.168.0.1/255.255.255.0
use sendfile = yes
map archive = no
map hidden = no
map read only = no
map system = no
store dos attributes = no
dos filemode = yes
oplocks = yes
level2 oplocks = yes
kernel oplocks = no
enable core files = no
deadtime = 30
load printers = no
printable = no
max protocol = SMB2
smb encrypt = disabled
min receivefile size = 16384
passdb backend = smbpasswd
smb passwd file = /etc/samba/smbpasswd
[Download2 (at TOSHIBA_1TB)]
comment = TOSHIBA_1TB's Download2 in TOSHIBA USB 3.5"-HDD
path = /tmp/mnt/TOSHIBA_1TB/Download2
dos filetimes = yes
fake directory create times = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[MOVIES (at TOSHIBA_1TB)]
comment = TOSHIBA_1TB's MOVIES in TOSHIBA USB 3.5"-HDD
path = /tmp/mnt/TOSHIBA_1TB/MOVIES
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[SOFTWARE (at TOSHIBA_1TB)]
comment = TOSHIBA_1TB's SOFTWARE in TOSHIBA USB 3.5"-HDD
path = /tmp/mnt/TOSHIBA_1TB/SOFTWARE
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[TEMP (at TOSHIBA_1TB)]
comment = TOSHIBA_1TB's TEMP in TOSHIBA USB 3.5"-HDD
path = /tmp/mnt/TOSHIBA_1TB/TEMP
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[TV (at TOSHIBA_1TB)]
comment = TOSHIBA_1TB's TV in TOSHIBA USB 3.5"-HDD
path = /tmp/mnt/TOSHIBA_1TB/TV
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[entware (at AX86U_DRIVE)]
comment = AX86U_DRIVE's entware in Samsung Flash Drive FIT
path = /tmp/mnt/AX86U_DRIVE/entware
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[skynet (at AX86U_DRIVE)]
comment = AX86U_DRIVE's skynet in Samsung Flash Drive FIT
path = /tmp/mnt/AX86U_DRIVE/skynet
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[nsru (at AX86U_DRIVE)]
comment = AX86U_DRIVE's nsru in Samsung Flash Drive FIT
path = /tmp/mnt/AX86U_DRIVE/nsru
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
Please use pastebin and/or insert this within the code </> blocks.
Try un-mounting and then physically removing the Toshiba HDD. Then reboot the router. Does the Samba page now display properly, with the Samsung flash drive being shown?
Yes!
And I can turn off "Enable share".
But I need the hard drive connected for rtorrent. I had the same flashdrive and hard disk working on my RT-AC3200 before.
What can I do?
My guess is that this is a bug in the web page caused by the double quote in the device name, TOSHIBA USB 3.5"-HDD.
As this double quote is embedded in the device there's not a lot you can do about it other than hope that it's fixed in a firmware update.
If you now plug the HDD back into the router does it mess up the Samba page like before?
I swapped the USB ports just in case. Turned on the router only with the flashdrive. The samba page looked fine.
Plugged the hard drive. Waited for it to automount. Refreshed samba page... issue is back.
The device is the same that worked fine with the RT-AC3200 running Merlin. If is a bug must have been introduced recently or maybe for the AX86U. I don't want to go to stock firmware to see if it is ASUS code issue or something introduced with Merlin.
I will try update for the recent Merlin version tomorrow. And will report back.
Haven't updated to latest Merlin because I don't think there would be any changes.
I did try edit smb.conf without the double quote... but that didn't help and when you restart the smb.conf is written again.
Also I brought back the RT-AC3200 I was using before. this is running Merlin 384.13
This is the smb.conf , the double quote is there.
[global]
netbios name = RT-AC3200
server string = RT-AC3200
unix charset = UTF8
load printers = no
printing = bsd
log file = /var/log.samba
log level = 0
max log size = 5
security = USER
guest ok = no
max connections = 7
host msdfs = no
wide links = no
use sendfile = yes
map archive = no
map hidden = no
map read only = no
map system = no
dos filemode = yes
oplocks = yes
kernel oplocks = no
deadtime = 30
load printers = no
printable = no
max protocol = NT1
[Download2]
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[MOVIES]
dos filetimes = yes
valid users = admin
read list = admin
write list = admin
[nsru]
comment = sdb1's nsru in SMI USB DISK
path = /tmp/mnt/sdb1/nsru
dos filetimes = yes
valid users = admin
read list = admin
write list = admin
Try this and se if you get rid of your problem. (if I understand this right)
#!/bin/sh
# /jffs/scripts/smb.postconf
CONFIG=$1
source /usr/sbin/helper.sh
pc_replace "comment = TOSHIBA_1TB's Download2 in TOSHIBA USB 3.5"-HDD" "comment = comment = TOSHIBA_1TB's Download2 in TOSHIBA USB 3.5-HDD" $CONFIG
pc_repalce "comment = TOSHIBA_1TB's MOVIES in TOSHIBA USB 3.5"-HDD" "comment = TOSHIBA_1TB's MOVIES in TOSHIBA USB 3.5-HDD" $CONFIG
I am guessing I create a file and paste that (correcting some typing mistakes). and then execute the script.
Wouldn't the " create issues when "...."..." ?
I got these errors:
admin@RT-AX86U:/jffs/scripts# ./smb.postconf
sed: TOSHIBA_1TBs: No such file or directory
sed: Download2: No such file or directory
sed: in: No such file or directory
sed: TOSHIBA: No such file or directory
sed: USB: No such file or directory
sed: 3.5-HDD": No such file or directory
sed: $CONFIG: No such file or directory
sed: pc_replace: No such file or directory
sed: "comment: No such file or directory
sed: =: No such file or directory
sed: SOFTWARE: No such file or directory
#!/bin/sh
CONFIG=$1
what give "cat /jffs/scripts/smb.postconf"
that file doesn't exist originally. I created one with this:
#!/bin/sh
CONFIG=$1
pc_replace "comment = TOSHIBA_1TB's Download2 in TOSHIBA USB 3.5"-HDD" "comment = TOSHIBA_1TB's Download2 in TOSHIBA USB 3.5-HDD" $CONFIG
pc_replace "comment = TOSHIBA_1TB's MOVIES in TOSHIBA USB 3.5"-HDD" "comment = TOSHIBA_1TB's MOVIES in TOSHIBA USB 3.5-HDD" $CONFIG
pc_replace "comment = TOSHIBA_1TB's SOFTWARE in TOSHIBA USB 3.5"-HDD" "comment = TOSHIBA_1TB's SOFTWARE in TOSHIBA USB 3.5-HDD" $CONFIG
pc_replace "comment = TOSHIBA_1TB's TEMP in TOSHIBA USB 3.5"-HDD" "comment = TOSHIBA_1TB's TEMP in TOSHIBA USB 3.5-HDD" $CONFIG
#!/bin/sh
CONFIG=$1
Isit working now?
The problem isn't with the smb.conf file.
The problem is with the data embedded within the USB device and the web code that displays it.
Okay, I got the impression that the problem was an " in the comment file.
But I'm probably wrong, sorry about that. Then I'm out
And do you think @RMerlin can do something about it or this issue was introduced by Asus?
Maybe tomorrow when I have a few hours with nobody at home I will back up every configuration on the router and then Reset it to stock ASUS firmware and see if the problem is there. Maybe try older ASUS firmwares for AX86U if I can find them,
