Can't disable Samba share and drives not showing on GUI
And do you think @RMerlin can do something about it or this issue was introduced by Asus?
Maybe tomorrow when I have a few hours with nobody at home I will back up every configuration on the router and then Reset it to stock ASUS firmware and see if the problem is there. Maybe try older ASUS firmwares for AX86U if I can find them,
Yes I'm sure this is something that's easily fixed if it's brought to the attention of Asus and/or @RMerlin.
See if there are any browser errors generated when you navigate to the Samba page.
The moment I switch off the harddrive the flashdrive folders tree appears on the list and things work.
There are some issues showing in the browser console as per screenshots:
