I just installed a new RT-AX86S as my main router, replacing an RT-AC86U. I want to use the older router as an AiMesh node. I also have an old RT-AC68U that's been in service as an AiMesh node. All three are running latest rMerlin firmware (386.7_2).
I've tried any number of times following the ASUS instructions. Reset the node, try and find it with and without a wired backhaul. I also explicitly set the node as an AiMesh node and then tried. I tried the button on the AiMesh page ("Add AiMesh Node") and the "Search" button you get to from the AiMesh node portion of the Network Map page. And I tried with both old routers. In all cases the main router fails to find any AiMesh nodes nearby. And none of the suggestions that come up are things I haven't tried.
I called ASUS support. Their only suggestion was to reset the main router to factory, which I tried, again to no avail. I can escalate the call at ASUS, but they'll undoubtedly tell me to go back to ASUS stock firmware (I didn't tell the low-level support folks I was using rMerlin). I wanted to first see if the rMerlin brain trust has any ideas?
Thank you!
Thank you!
