Neo-ST
Hi all, new here.
I'm having problems with connecting a brand new AX86U with my 4G router set in bridge mode.
Steps I've taken:
- Set my 4G router (Teltonika RUTX09) into bridge mode (straightforward process, just needed to type in MAC address of my Asus)
- Enabled DHCP server on LAN on Teltonika (otherwise it won't work)
- Set Teltonika to static address 192.168.1.1
- Asus is on 192.168.50.1
- On Asus in WAN - Wan Connection type, set to Automatic
- On same page, set DNS to Google's
- On LAN settings, DHCP server is enabled
Then:
- Plugged RUTX09 to Asus' WAN port
- I can access RUTX09 normally, log shows mobile connection established, bridge mode working
- In Asus dashboard, network map shows external WAN IP (which is good) - connection established, I have access to Internet
- RUTX09 assigns 192.168.1.139 to be WAN IP for Asus
However, after a few minutes, problems start.
Constant connection drops, in log visible as "Link DOWN". Multiple times it tries to re-establish connection, succeeds eventually after 4-5 tries. Then access to Internet is restored but not for long, again after a few minutes the problems start, and so on in circle...
I'm not sure why is this happening. Is there any specific setting that I didn't set properly or messed up ? If so, which one?
Note:
I tried connecting RUTX09 with bridge mode enabled directly to my PC, and it works flawlessly, no connection drops, so it's not RUT's problem.
Problems start after connecting it to Asus.
Clean log of Asus, before disconnects start to happen till the connection restore:
Screenshot of WAN settings in Asus:
So if someone can solve this mistery, I'd be grateful. I thought I bought a good (and expensive) router, but so far it rejects to work the way I'd want it.
The only way it works properly with RUTX09 is if they're both in router mode and then I have double NAT which I don't want.
Steps I've taken:
Then:
Note:
Dec 19 19:07:39 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:07:44 WAN(0) Connection: WAN(0) link down.
Dec 19 19:07:46 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:07:47 WAN(0) Connection: WAN(0) link up.
Dec 19 19:07:47 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:07:53 wan: finish adding multi routes
Dec 19 19:07:56 BWDPI: force to flush flowcache entries
Dec 19 19:07:56 kernel: udb_core lock_num = 4
Dec 19 19:07:56 WAN(0) Connection: WAN was restored.
Dec 19 19:07:56 BWDPI: rollback fc
Dec 19 19:07:58 kernel: SHN Release Version: 2.0.7 371dd35_RELS_8
Dec 19 19:07:58 kernel: UDB Core Version: 0.2.20
Dec 19 19:07:58 kernel: Registered DNS Req parsing
Dec 19 19:07:58 kernel: sizeof forward pkt param = 280
Dec 19 19:07:58 BWDPI: fun bitmap = 4bf
Dec 19 19:07:58 A.QoS: qos_count=0, qos_check=0
Dec 19 19:08:01 rc_service: udhcpc_wan 23447:notify_rc stop_samba
Dec 19 19:08:01 Samba Server: smb daemon is stopped
Dec 19 19:08:02 rc_service: udhcpc_wan 23447:notify_rc start_samba
Dec 19 19:08:03 dhcp client: bound 192.168.1.139/255.255.255.0 via 192.168.1.1 for 43200 seconds.
Dec 19 19:08:09 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:08:12 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:08:14 WAN(0) Connection: WAN(0) link up.
Dec 19 19:08:14 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:08:22 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:08:25 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:08:25 wlceventd: wlceventd_proc_event(662): eth6: Disassoc A8:xxxxxx:52, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Dec 19 19:08:25 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:xxxxxxx:52, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Dec 19 19:08:26 WAN(0) Connection: WAN(0) link up.
Dec 19 19:08:26 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:08:46 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:08:48 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:08:50 WAN(0) Connection: WAN(0) link up.
Dec 19 19:08:50 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:08:50 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:08:50 rc_service: cfg_server 2387:notify_rc update_nbr
Dec 19 19:08:50 rc_service: waitting "restart_wan_if 0" via wanduck ...
Dec 19 19:08:53 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:08:56 WAN(0) Connection: WAN(0) link up.
Dec 19 19:08:56 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:09:04 wan: finish adding multi routes
Dec 19 19:09:05 WAN(0) Connection: WAN was restored.
Dec 19 19:09:07 BWDPI: force to flush flowcache entries
Dec 19 19:09:07 kernel: udb_core lock_num = 4
Dec 19 19:09:07 BWDPI: rollback fc
Dec 19 19:09:09 kernel: SHN Release Version: 2.0.7 371dd35_RELS_8
Dec 19 19:09:09 kernel: UDB Core Version: 0.2.20
Dec 19 19:09:09 kernel: Registered DNS Req parsing
Dec 19 19:09:09 kernel: sizeof forward pkt param = 280
Dec 19 19:09:09 BWDPI: fun bitmap = 4bf
Dec 19 19:09:09 A.QoS: qos_count=0, qos_check=0
Dec 19 19:09:11 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link DOWN.
Dec 19 19:09:12 rc_service: udhcpc_wan 24852:notify_rc stop_samba
Dec 19 19:09:12 Samba Server: smb daemon is stopped
Dec 19 19:09:13 rc_service: udhcpc_wan 24852:notify_rc start_samba
Dec 19 19:09:14 dhcp client: bound 192.168.1.139/255.255.255.0 via 192.168.1.1 for 43200 seconds.
Dec 19 19:09:17 WAN(0) Connection: WAN(0) link down.
Dec 19 19:09:18 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: 1) Link Up at 1000 mbps full duplex
Dec 19 19:09:20 WAN(0) Connection: WAN(0) link up.
Dec 19 19:09:20 rc_service: wanduck 1521:notify_rc restart_wan_if 0
Dec 19 19:09:22 wan: finish adding multi routes
Dec 19 19:09:23 WAN(0) Connection: WAN was restored.
Dec 19 19:09:25 BWDPI: force to flush flowcache entries
Dec 19 19:09:25 kernel: udb_core lock_num = 3
Dec 19 19:09:25 BWDPI: rollback fc
Dec 19 19:09:27 kernel: SHN Release Version: 2.0.7 371dd35_RELS_8
Dec 19 19:09:27 kernel: UDB Core Version: 0.2.20
Dec 19 19:09:27 kernel: Registered DNS Req parsing
Dec 19 19:09:27 kernel: sizeof forward pkt param = 280
Dec 19 19:09:27 BWDPI: fun bitmap = 4bf
Dec 19 19:09:27 A.QoS: qos_count=0, qos_check=0
Dec 19 19:09:30 rc_service: udhcpc_wan 25758:notify_rc stop_samba
Dec 19 19:09:30 Samba Server: smb daemon is stopped
Dec 19 19:09:31 rc_service: udhcpc_wan 25758:notify_rc start_samba
Dec 19 19:09:32 dhcp client: bound 10.xxxxxxx/255.255.255.248 via 10.xxxxxxx for 3600 seconds.
