kayone
I have RT-AC68U and I've tried to get QoS to work both in stock firmware and Merlin with no luck,
I've had QoS setup and working correctly on my old router using DD-WRT so I think I understand the concept and how it's supposed to work,
I've also read as many guides as I could on AC68U and other asus routers but most of them seems to be outdated(?), for example the screen shots posted http://www.smallnetbuilder.com/forums/showthread.php?t=15279 are different than mine, I don't have "User specify rule list" on my main page.
couple of questions,
I set both my Download/Upload limit to 1mb/s to see if this thing works at all and I was still downloading at 25mb/s. I don't see how QoS could work if it's not limiting my download to the rate I set on the first page.
another question, in User defined rules, do I have to specify all the rules for QoS to work? Are "Destination Port" and "Transferred" field required for the rule to work?
I assume "Enable Smart QoS", is the main toggle for QoS, since when I turn it off it hides the "Upload/Download Bandwidth". What throws me off a bit is "Smart", is that just asuse's flavor/marketing term for QoS?
