blitzkrieg
Hi all
I've an RT-AC66U_B1 running Merlin's 380.67.
OpenVPN setup as follows:
TUN. Push LAN to clients. Direct clients to redirect Internet traffic. Respond to DNS. Advertise DNS to clients.
A DLink router is connected to the Asus through each other's LAN port and in the same 192.168.4.0/25 subnet. So it is essentially a switch.
I can connect to OpenVPN successfully and able to access a NAS server no problem. But I can't ping nor access the DLink router 192.168.4.2 while in OpenVPN. However, I can ping the PCs, Asus router and Android devices.
Any additional routing/iptables need to be added?
Here's the untouched iptables:
Here's the netstat routing table:
Simple network view:
OpenVPN setting:
/root# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere
ACCEPT udp -- anywhere anywhere udp dpt:1194
DROP icmp -- anywhere anywhere icmp echo-request
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
DROP all -- anywhere anywhere state INVALID
PTCSRVWAN all -- anywhere anywhere
PTCSRVLAN all -- anywhere anywhere
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
INPUT_ICMP icmp -- anywhere anywhere
Chain FORWARD (policy DROP)
ipttolan all -- anywhere anywhere
iptfromlan all -- anywhere anywhere
SECURITY all -- anywhere anywhere
NSFW all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain ACCESS_RESTRICTION (0 references)
Chain FUPNP (0 references)
Chain INPUT_ICMP (1 references)
RETURN icmp -- anywhere anywhere icmp echo-request
RETURN icmp -- anywhere anywhere icmp timestamp-request
ACCEPT icmp -- anywhere anywhere
Chain NSFW (1 references)
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (1 references)
RETURN tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN
RETURN tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST
RETURN icmp -- anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
RETURN all -- anywhere anywhere
Chain iptfromlan (1 references)
RETURN all -- anywhere anywhere account: network/netmask: 192.168.4.0/255.255.255.128 name: lan
Chain ipttolan (1 references)
Chain logaccept (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
44.125.x.1 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
192.168.4.0 0.0.0.0 255.255.255.128 U 0 0 0 br0
10.8.0.0 0.0.0.0 255.255.255.128 U 0 0 0 tun21
44.125.x.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 44.125.x.1 0.0.0.0 UG 0 0 0 eth0
OpenVPN setting:
