hungarianhc
Having the weirdest issue. I had the R7000 set up w/ the default firmware, and my macbooks couldn't connect at a rate above 54mbps. I thought it might have to do with the firmware so I flashed DD-WRT. Same issue... Interestingly enough, in DD-WRT, if I start browsing the wireless settings, the highest "transmission fixed rate" it will let me set is 54mbps. Does anyone know what setting might be messed up here?
