What do you have connected to the router while attempting the upgrade? If you have a USB drive connected you might want to try with this safely removed.When I try to upload the TRX file from the _5 release on my ASUS RT-AC68R, I get a message that it was unsuccessful - it may result from an incorrect image or error transmission. The ZIP file tested successful when extracting the TRX file from it.
Any suggestions?
It seems like the USB drive is automatically dismounted when I attempt an update. After it fails, the drive is disconnected. Rebooting the modem mounts it properly again. Trying the update again causes the USB drive to dismount again so it seems like there's definitely a cause-effect here.
But even when it's not mounted the update fails with the same message.
Welcome To SNBForums
