cubagoodingrobot
I can't seem to get the two of them to work simultanously. I've gone through the post here:
http://www.snbforums.com/threads/force-google-safesearch.22738/
I created dnsmasq.conf.add and hosts.add files to forcesafesearch as described. On it's own it works fine: when I nslookup google, it points to 216.239.38.120, and the log files show that the .add files are being appended.
When I try to point to OpenDNS, either via the DNSFiltering control or the LAN>DHCP>DNS Server settings, that's when I lose the forcesafesearch. I've tried setting DNSFiltering to OpenDNS Home and leaving DNS Server settings blank, I've also tried leaving DNSFiltering off and setting DNS servers to the OpenDNS server IPs, I've also tried setting DNSFiltering to Router and setting DNS servers to OpenDNS server IPs. In all of these cases, OpenDNS works, but I lose the forcesafesearch, and nslookup shows a long list of google IPs. It looks like the user snevah admin had the same problem in the above thread and solved it by setting the DNS Servers with the OpenDNS IPs, but like I said, that didn't work for me. Anybody have any advice on how to make this work together?
I thought about making it work like this, but since this is all pretty new to me, I'm not sure if it's a legit solution: What if I set the DNSFiltering to Router, leave the DNS Server settings blank, and then in my dnsmasq.conf.add file, could I set it up so that the cname values for google get read first, then any thing that is not google would get sent to the OpenDNS IPs? would that work?
