Change SD Card Mount options on RT-N66U
gijor33
Hi guys,
How can I change the mount options on the internal SD Card in my Asus RT-N66U?
When I type mount, I get the following output
admin@ASNet-WIFI:/# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
[B]/dev/sda1 on /tmp/mnt/entware type ext2 (rw,nodev,noatime)[/B]
I want to change the line in bold to use
data=writeback,discard,rw,nodev,noatime
I have added an fstab file to /jffs/configs and made sure chmod was 755
As you can see it looks as though the system is reading my new fstab config file
admin@ASNet-WIFI:/# find -name fstab
./jffs/configs/fstab
./tmp/etc/fstab
admin@ASNet-WIFI:/# cat /jffs/configs/fstab
/dev/sda1 /tmp/mnt/entware ext2 defaults,data=writeback,discard,rw,nodev,noatime 0 0
admin@ASNet-WIFI:/# cat /tmp/etc/fstab
admin@ASNet-WIFI:/#
But it just doesn't take that as shown in the mount command above
The other thing which I saw in another post while searching (no answer to it either) was that on boot up it detects an ext4 file system as shown in the system logs and I have no idea why because I used makefs.ext2
Oct 13 14:46:57 hotplug[345]: USB /dev/sda1(ext4) failed to mount at the first try!
Oct 13 14:46:57 hotplug[345]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/entware
Any help would be appreciated. I'd like to make my SD Card as fast as possible with the writeback option and last as long as possible with the discard mount option.
Andy
I saw that you formated your drive in ext4. This is not supported with your router!
To my knowledge only ext3 (or ext2) should used and it will then work without problems! ;)
With kind regards
Joe :cool:
Noob question is there an SD card inside our RT-N66U? And what is the flash memory size is it 32MB or 64MB?
You can put an micro SD card into the router - there is an internal slot avaliable. Only the opening of the router case is a little bit tricky.
I run a 1 GB SD card in my main router.
With kind regards
Joe :cool:
With kind regards
Joe :cool:
Thank you. But can you explain what putting a 1 GB SD card in this router does? Also if you know does this router have 32 or 64 MB of flash RAM?
With kind regards
Joe :cool:
No that's not correct. I mentioned I used makefs.ext2 to format it. Mount command shows that it's type ext2 as well
It just means you don't have to have an external USB memory stick hanging out the back. I have a 32gb in mine from my phone while I wait for the 16gb one I just ordered to arrive
The ext4 warning is just a cosmetical bug introduced when Asus added ext4 support for the RT-AC56U/AC68U. The router's filesystem detection code is a bit quirky it seems, however it won't prevent your disk from being properly mounted.
Ah cool. Thanks for the confirmation. I thought that must have been it because it all mounts fine.
Ok thank you. Makes no sense that Asus would put a SD card slot inside and that you have to take it apart to access it and void your warranty. I thought Asus was much smarter than that.
J Auto mounting internal microSD card of the RT-N66U ? ASUS N Routers & Adapters 5
