Is there a way to change the default port for the web server in Merlin? I used to do this in Tomato just to add a bit more security.
Thanks.
Only the HTTPS port can be changed. Since you're after improving security, it would probably be a good idea anyway to switch to HTTPS only, and then select the desired port.
Welcome To SNBForums
