DDNS at first works as expected and record is registered on asuscomm.com
Problem arise when you go manually to network-map (first menu on left) and select "internet status" and apply for a switch off of "internet connection". Wait for changed to apply.... and then back to "on" to restore wan connection and get new IP.
After that I would expect to have DDNS to notify dns server for ip change, but looking at logs, nothing is called. And DDNS isn't updated (never)
this are logs from router manually disconnected to connected again with new IP
and inadyn isn't called.....
don't know if "ddns: WAN(0) IP is empty.(10)" mean something... I'm NOT in dualwan and IP is taken correctly and shown in logs a second before.
Then if I go manually to DDNS page (under WAN) and hit "APPLY" with no changes.... it does correctly call inadyn
yet I've to test if ddns get update if there's a loss of connection disconnecting cable.... can't test it right now as router is hard to reach.
any idea?
thanks
Apr 19 21:41:04 WAN_Connection: WAN was exceptionally disconnected.
Apr 19 21:41:43 rc_service: httpd 19415:notify_rc restart_wan_if 0
Apr 19 21:41:45 pppd[3579]: pppd 2.4.7 started by admin, uid 0
Apr 19 21:41:46 pppd[3579]: Connected to xx:xx:xx:xx:xx:xx via interface eth0
Apr 19 21:41:46 pppd[3579]: Connect: ppp0 <--> eth0
Apr 19 21:41:46 pppd[3579]: PAP authentication succeeded
Apr 19 21:41:46 pppd[3579]: peer from calling number xx:xx:xx:xx:xx:xx authorized
Apr 19 21:41:46 wsdd2[21811]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Apr 19 21:41:46 pppd[3579]: local IP address aa.bb.ccc.70
Apr 19 21:41:46 pppd[3579]: remote IP address 192.168.aaa.bbb
Apr 19 21:41:46 wan: finish adding multi routes
Apr 19 21:41:46 WireGuard: Stopping server.
Apr 19 21:41:47 WireGuard: Starting server.
Apr 19 21:41:47 ddns: WAN(0) IP is empty.(10)
Apr 19 21:41:47 rc_service: ip-up 3585:notify_rc start_vpnserver1
Apr 19 21:41:47 rc_service: ip-up 3585:notify_rc stop_samba
Apr 19 21:41:47 rc_service: waitting "start_vpnserver1" via ip-up ...
Apr 19 21:41:48 wsdd2[21811]: Terminated received.
Apr 19 21:41:48 Samba_Server: smb daemon is stopped
Apr 19 21:41:49 rc_service: ip-up 3585:notify_rc start_samba
Apr 19 21:41:49 Samba_Server: daemon is started
Apr 19 21:41:57 zcip_client: configured 169.bbb.ccc.ddd
Apr 19 21:41:59 WAN_Connection: WAN was restored.
Apr 19 21:44:23 rc_service: httpd 19415:notify_rc restart_ddns
Apr 19 21:44:23 ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Apr 19 21:44:23 ddns: Clear ddns cache.
Apr 19 21:44:23 ddns: Start Inadyn(10).
Apr 19 21:44:23 inadyn[4339]: In-a-dyn version 2.10.0 -- Dynamic DNS update client.
Apr 19 21:44:23 inadyn[4339]: Update forced for alias obfuscated.asuscomm.com, new IP# aaa.bbb.ccc.70
Apr 19 21:44:23 inadyn[4339]: alias address=<aaa.bbb.ccc.70>
Apr 19 21:44:23 inadyn[4339]: request<GET /ddns/update.jsp?hostname=obfuscated.asuscomm.com&myip=aaa.bbb.ccc.70&model=RT-AX86U_PRO&fw_ver=3.0.0.4.388.6_2 HTTP/1.0^M Authorization: Basic obfuscated^M Host: ns1.asuscomm.com^M User-Agent: inadyn/2.10.0 https://github.com/troglobit/inadyn/issues^M ^M >
Apr 19 21:44:24 inadyn[4339]: [response_update]HTTP/1.1 200 OK^M Date: Fri, 19 Apr 2024 19:44:24 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Apr 19 21:44:24 inadyn[4339]: Updating cache for obfuscated.asuscomm.com
any idea?
thanks
