Change Wireless 2.4GHz & 5GHz MAC address
The jffs partition is part of the router's internal storage, it cannot be anywhere else. You need custom scripts enabled in the Merlin GUI to automatically run them.
Many thanks, Looks like this no longer works, The reason i wanted to change my wifi mac address is this, There is a lot of devices connected by wifi, Streaming, Games consoles, Smart tvs, phones, The amount of earache I would get when all these devices have to be reconnected to a new router.
The plan is to swap out an ageing N66u that is on johns f/w late at night so that no-one would notice, I wanted to pull that out and replace it with an RT-AC88u on latest merlin f/w.
My modem is a virgin superhub in modem only mode.
Any ideas you clever people?
Client devices shouldn't be using the MAC address of the access point to connect, they should be using the SSIDs. So provided you keep the SSIDs the same on your new router you should be OK.
Changing your router (and therefore the WAN MAC address) will give you a new public IP address. That shouldn't normally be a problem but if you think it is then you can clone your old WAN MAC address in the WAN settings.
OMG, for years I always thought it was a mixture of the two, SSID aand the mac address, The SSID will be the same.
I never for one moment thought it would be just the SSID.
I will leet you all know how it went tomorrow.
I'm really interested in changing the Wifi Mac Address's on my Asus RT-96U with Merlin FW. I've tried all the methods above and nothing works.
If you're so curious why I want to it is because I have this feeling that routers from TP-link maybe netgear are purposefully interfering with Asus Routers. Changing the WAN MAC address is a night and day difference with the ISP (Cox Fiber), and I"m sure they use plenty of cheap TP-link type backhaul equipment.
Is there a law or something preventing this from being changed? I don't know why they wouldn't want you to be able to change something like this. Especially if it's your wifi equipment.
Anyways thanks in advance for reading and replying if you have any insights.
FWIW - Cox generally uses Netgear and Vantiva these days for the carrier provided Gateways and or Modems (Vantiva has been on a big M&A action consolidating many players, so one might see a brand like Arris or Technicolor, but these days it's all Vantiva)
I personally have never observed TP-Link as provided equipment from them... and through personal contact at Cox, there is no TP-Link stuff inside the "back end" - most of it is Nokia or Ericsson, with some Cisco and Juniper as needed for the customer datapaths...
No real reason not be to able to change the MAC address, but at the same time, what problem is trying to be solved here?
Cox has no skin in the game on what happens on the other side of their modems - so if your Router is Asus, Netgear, Linksys, etc, they really don't care...
