Choosing new router
sounds like the speaker is not shielded against EMI or you have a radiating source too close. Try moving wireless transmitters further away. If these are shielded speakers, then replace the cable with a correctly shielded one.
The router is 50CM away from the speakers, that is the maximum I can do. It still does that PSSSSS and sparks noise (It is very weak noise, but still annoying).
My speakers are not shielded I guess, they have Non Polarized AC Plug, I have seen on another forum I need something like this to fix the issue https://www.amazon.co.uk/dp/B015J289ZG/?tag=smallncom-21
its called mains conditioner, what do you think ?
It has something to do with the electric because if I disconnect the RCA cables it still does that till I completely turn off the speakers (or the router) so it stops. Do you think the mains conditioner will fix the problem ?
unplug all electronics one by one and see if/when the noise goes away. See if it is a wall wart power supply or a device. If it does not then, you need some sort of RF filter on either the power or shielding of the the speaker itself. a simple ferrite core choke on the power cable at the speaker may be enough. Or use a power filter. i would start with an inexpensive one.
The router is the cause. If I turn it off the speakers doesnt do the sparks. I biught the mains conditioner if it doesnt work I will return it back to Amazon.
Try plugging the router in a different power outlet to see if it makes any difference. I've seen cases where the actual source of the problem was the power bar itself where the equipment was plugged.
If the mains conditioner wont work, ill try what you suggested, thanks for the help.
