Cisco Anyconnect VPN Stability on RT-AC68U
If both CTF and FA were active with NAT acceleration it was probably the flow acceleration (FA). FA was so flaky and unstable for me I enabled traffic statistics and rebooted to only have CTF. Now perfectly stable. No issues with Anyconnect for me with this setup on my 68U. Any chance of getting a setting to just disable FA?
If you are using the AC68 (as am I), then Johns fork of the older release supports settings Level 1 CTF on the Nat accel option, which is just CTF:
"In Asus's particular case (since it's the one I'm most familiar with - someone else could fill us up on the other manufacturers), they are handling this as a "Hardware acceleration level". Level 1 is just traditional CTF. Level 2 is traditional CTF + FA. One coming product that does support both levels will have to downgrade from Level 2 to Level 1 when one of the new features they are adding will be enabled."
https://www.snbforums.com/threads/broadcoms-hardware-acceleration.18144/
With NAT acceleration disabled, I still encounter "VPN Reconnecting ..." ---- at a loss and will probably just deal with it until the cost of mesh networking HW comes down and switch over to a different manufacturer. I also connect with WiFi through other houses and hotels and I never have the issue. Refuse to pay for a $250 router twice.
I used to have a similar issue as my work requires Cisco anyconnect vpn. My setup has changed since then but my fix was clearing nvram, so I would advise to update to .65 if supported and then clear nvram or 30/30/30 method after upgrade firmware.
I use Anyconnect with an 87U and latest Merlin firmware and "touch wood" have never had a disconnect, even when using it for a full working day.
I do a nvram clear after each firmware upgrade and reboot the router every night when house asleep, which may help.
Back to update all on the outcome. Finally gave up on the AC-87R (after 5 RMAs) and tested the AC-3100. No issues whatsoever and life is good with the AC-3100. Must have been a hardware issue with that model, or something that I don't about anymore.
The AC-3100 works like a charm out of the box.
Having this issue on my wife's work computer which connects via VPN. I recently purchased two t mobile 1900s and did the trick to turn them into ac68u units - and running them as an aimesh deal. Seems to only affect her wirelessly - as wired is fine. Will try some of the things mentioned here and other places I've found, but have any new tricks or ideas been discovered?
Try turning off (disable) airtime fairness under the wireless professional tab. Some connections really don't like this setting.
