pardysound
Hi All,
I have the first world problem of having an awesome fiber ISP and my package allows me 250Mbps up and down. I can verify this speed to my modem by connecting directly to the modem and running a speedtest (speedtest.net) However as soon as I put the router in line the best I can get is 135Mbps.
So far in my trouble shooting I have:
-removed all other items on the network
-disabled the radio
-replaced the cable between modem and router
-reset the router to default settings
All with no change in performance. According to SMB's test of the router I should have 687Mbps WAN-LAN and 689Mbps LAN-WAN.. so buy the specs the hardware should be able to support 250Mbps no problem...
Hopefully someone can suggest what could be the cause... thanks for your time.
-disabled the radio
