Compile Merlin 384 arm-brcm-linux-uclibcgnueabi-gcc: command not found
IRONFELIX
Hi !!!!
I used this https://github.com/RMerl/asuswrt-merlin/wiki/Compile-Firmware-from-source-using-Ubuntu instruction for compile 384 version of Merlin by myself (on i386 Ubuntu).
In a result, I received this error
* System Logging Utilities
klogd (KLOGD) [Y/n/?] y
Use the klogctl() interface (FEATURE_KLOGD_KLOGCTL) [N/y/?] n
logger (LOGGER) [Y/n/?] y
syslogd (SYSLOGD) [Y/n/?] y
Rotate message files (FEATURE_ROTATE_LOGFILE) [Y/n/?] y
Remote Log support (FEATURE_REMOTE_LOG) [Y/n/?] y
Support -D (drop dups) option (FEATURE_SYSLOGD_DUP) [N/y/?] n
Support syslog.conf (FEATURE_SYSLOGD_CFG) [N/y/?] n
Read buffer size in bytes (FEATURE_SYSLOGD_READ_BUFFER_SIZE) [512] 512
Circular Buffer support (FEATURE_IPC_SYSLOG) [N/y/?] n
Linux kernel printk buffer support (FEATURE_KMSG_SYSLOG) [N/y/?] n
/home/sergo/asuswrt-merlin.ng/release/src/router/busybox/scripts/gcc-version.sh: Line 11: arm-brcm-linux-uclibcgnueabi-gcc: Command not found
Anybody can help me and explain this mistake?
You need to install and configure the toolchain. See the README in the toolchain repo.
