Best log message to detect boot/reboot
wan0_bound.env comes from dhcpc IIRC.
I don't have /tmp/WAN0_state on my router.
Still on the right track then, I stumbled on that haphazardly somehow
wanup_date="$(cat $infile | awk '/Initial clock set|WAN was restored/ {a=$0} END{print substr (a,1,15)}')"
wanup_secs="$(/bin/date --date="$wanup_date" -D '%b %e %T' +'%s')"
Thanks, I run the strings through a loop for terminal messages and falling back through the 4 search methods, but I got to learn about substr, I may have a use for it if I can experiment with it more
Hows your luck using date to convert a date/time to another TZ? In all my tests it seems this busybox date doesnt support it
That's not something I've ever thought about, because I've never needed to do it. I can't think of a situation where I would want to process timestamps on the router that weren't in my locale. That's more the kind of thing that databases and remote log servers would do when collecting data from different geographical regions. That seems beyond the scope of this thread.
EDIT: I've just tested this and it seems to work fine with different time zones. It even compensates for DST. But you do have to set $TZ so that it matches what was set on the source when the timestamp string was created.
I had 9 lines to convert router default date/time to router TZ ha
Ive abandoned the default date/time check though, you're right and just validating its appearance vs last NTP sync (or no found NTP sync) as the script will only run after NTP has been synced and WAN up
