connect to OpenVPN from same lan
@john9527 is there a setting/configuration for the listen interface?
Edit: I'm also on your fork (V33), my router is btw. an AC66U
By default, it now only binds to the WAN IP address. If you would like to change it, you can use an 'openvpnserver1.postconf' (or 'openvpnserver2.postconf') script to change the IP or delete the local line completely to have it bind to all interfaces.
