Connection issues (or wifi issues?)
Some logs when I rebooted the ISP router if it helps:
Sep 11 14:44:51 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link DOWN.
Sep 11 14:44:59 WAN(0)_Connection: WAN(0) link down.
Sep 11 14:46:01 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
Sep 11 14:46:02 WAN(0)_Connection: WAN(0) link up.
Sep 11 14:46:02 rc_service: wanduck 1128:notify_rc restart_wan_if 0
Sep 11 14:46:02 custom_script: Running /jffs/scripts/service-event (args: restart wan_if)
Sep 11 14:46:02 custom_script: Running /jffs/scripts/wan-event (args: 0 stopping)
Sep 11 14:46:02 wsdd2[8957]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Sep 11 14:46:02 custom_script: Running /jffs/scripts/wan-event (args: 0 disconnected)
Sep 11 14:46:02 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Sep 11 14:46:04 custom_script: Running /jffs/scripts/wan-event (args: 0 init)
Sep 11 14:46:04 custom_script: Running /jffs/scripts/wan-event (args: 0 connecting)
Sep 11 14:46:04 custom_script: Running /jffs/scripts/wan-event (args: 0 disconnected)
Sep 11 14:46:04 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Sep 11 14:46:25 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link DOWN.
Sep 11 14:46:28 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
Sep 11 14:46:28 WAN(0)_Connection: WAN(0) link up.
Sep 11 14:46:28 rc_service: wanduck 1128:notify_rc restart_wan_if 0
Sep 11 14:46:28 custom_script: Running /jffs/scripts/service-event (args: restart wan_if)
Sep 11 14:46:28 custom_script: Running /jffs/scripts/wan-event (args: 0 stopping)
Sep 11 14:46:28 custom_script: Running /jffs/scripts/wan-event (args: 0 disconnected)
Sep 11 14:46:29 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Sep 11 14:46:31 custom_script: Running /jffs/scripts/wan-event (args: 0 init)
Sep 11 14:46:31 custom_script: Running /jffs/scripts/wan-event (args: 0 connecting)
Sep 11 14:46:31 custom_script: Running /jffs/scripts/wan-event (args: 0 disconnected)
Sep 11 14:46:31 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Sep 11 14:51:12 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link DOWN.
I see those logs too, I don't know if it means something:
Sep 11 13:15:12 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:15:13 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=1c, status=1, mac=00:00:00:00:00:00
Sep 11 13:15:13 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:15:13 bsd: bsd: Skip STA<mac_hidden>reject BSSID
Sep 11 13:17:23 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:17:23 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=1d, status=1, mac=00:00:00:00:00:00
Sep 11 13:17:23 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:17:23 bsd: bsd: Skip STA:<mac_hidden>reject BSSID
Sep 11 13:18:28 bsd: bsd: Sending act Frame to <mac_hidden>with transition target eth7 ssid <router_mac>
Sep 11 13:18:29 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=1e, status=1, mac=00:00:00:00:00:00
Sep 11 13:18:29 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:18:29 bsd: bsd: Skip STA:<mac_hidden> reject BSSID
Sep 11 13:20:39 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:20:39 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=1f, status=1, mac=00:00:00:00:00:00
Sep 11 13:20:39 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:20:39 bsd: bsd: Skip STA:<mac_hidden> reject BSSID
Sep 11 13:21:44 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:21:45 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=20, status=1, mac=00:00:00:00:00:00
Sep 11 13:21:45 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:21:45 bsd: bsd: Skip STA:<mac_hidden>reject BSSID
Sep 11 13:23:55 bsd: bsd: Sending act Frame to <mac_hidden>with transition target eth7 ssid <router_mac>
Sep 11 13:23:55 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=21, status=1, mac=00:00:00:00:00:00
Sep 11 13:23:55 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:23:55 bsd: bsd: Skip STA:<mac_hidden>reject BSSID
Sep 11 13:25:00 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:25:01 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=22, status=1, mac=00:00:00:00:00:00
Sep 11 13:25:01 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:25:01 bsd: bsd: Skip STA:<mac_hidden> reject BSSID
Sep 11 13:27:11 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:27:11 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=23, status=1, mac=00:00:00:00:00:00
Sep 11 13:27:11 bsd: bsd: BSS Transit Response: STA reject
Sep 11 13:27:11 bsd: bsd: Skip STA:<mac_hidden> reject BSSID
Sep 11 13:28:16 bsd: bsd: Sending act Frame to <mac_hidden> with transition target eth7 ssid <router_mac>
Sep 11 13:28:16 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=23, status=1, mac=00:00:00:00:00:00
Sep 11 13:28:16 bsd: bsd: BSS Transit Response: not for token 24
Sep 11 13:28:17 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=24, status=1, mac=00:00:00:00:00:00
Sep 11 13:28:17 bsd: bsd: BSS Transit Response: not for token 25
At this point I'd try swapping the two routers and see if the problem persists (or if issues follow the router).
Have you talked with your ISP about your issues?
Hey @Morris no, I didn’t, they probably says since it is bridge mode, they issue is in the router, but I can try
My experience is to have fairly concrete proof before wasting the call to the ISP. But who knows, their standard diagnostic test might find something.
Does seem too be pointing to the router at this point but never know.
Thanks @drinkingbird. I have an spare router, ac88u ready to use. Next time I will connect the cable from the ISP router, if it works without an reboot, it’s clear the issue is in the AXE10000
And what I can see is more often the issue… I will swap the routers after my job
Hi
14 days without the issue. There is only one thing I have changed. Now both asus, router and node, are connected by wifi, instead cable… obviously the signal is worst
Connect the cable again. If problem returns replace the cable. The cable must be away from sources of interference such as transformer, motor florescent lights.
