Contention between dropbear and web interface
pe78420
My Asus RT-AC66U web interface is setted as https, port 443.
The sshd (dropbear) is enabled for wan access with rsa key and port 443.
No problem to access ssh from the outside (wan) but now the local webui is inaccessible !
I've forgotten to return the webui setting to http instead of https and now it seems I get contention between dropbear and the webui.
Before to do a factory reset... Is there a way to modify the webui using command line via ssh in order to use the webui with http ?
Many thanks in advance and best regards,
pe78420
This will move the https instance of the webui back to the default port 8443:
nvram set misc_httpsport_x=8443
nvram set https_lanport=8443
nvram commit
service restart_httpd
Port 443 is normally used by AiCloud, so probably not a good idea to use that for ssh either.
