TheLyppardMan
I discovered this evening that if I switch on a 5GHz guest network, it messes up my control channel settings.
I have the 5GHz band locked to channel 36 because my Amazon Fire TV won't connect to it if the channel is in the 100's range. However, if I switch on a 5GHz guest network, the 5GHz band moves to the 100's zone. On the initial test, it moved to channel 116, so I repeated the exercise and it moved to channel 108. I checked and my Amazon Fire TV had lost the wi-fi connection. Note: the setting in the GUI was still showing channel 36 as the control channel.
I'm using the latest Merlin build on an RT-AC87U router.
