JT Strickland
RT-AC86U primary router with Merlin 384.14 beta
RT-AC68U for Aimesh Node, ethernet priority with stock 3.0.0.4.384_81351-gcb63868
Small home and office arrangement, about 100 feet apart.
Question 1: Can I attach a small NAS to my Aimesh node's usb port? If so, do I configure it through the primary router? Well, I suppose that's the only way to do it without resetting it to factory defaults?
Question 2: PPoE is enabled on the Advanced Settings > Wan tab. I think I may have enabled it following some instructions, perhaps for setting up DNS servers, but it may have been on and I have just been overlooking it. Should I disable it?
I have installed PuTTY, amtm, Entware, diversion, skynet, pixelserv-tls, and created a swap file in the last couple of days. I created a 2 Gb swap file on a 32 Gb thumb drive, anthough I wasn't sure what size usb drive to use. I have wanted to do it for some time, but was intimidated by the prospect, but it wasn't as difficult as I had imagined. Anyway, since then, my processors are pegged out at 97% and 96%, and the RAM is at 95%. Is this normal, or have I got something screwed up? I figured the activity would subside some with the swap file, but seems like it has increased.
It hasn't been long since I didn't know the difference between a LAN and a WAN, and now I am screwing up perfectly good scripts! (I guess).
I appreciate any help and advice.
TIA,
jts
TIA,
jts
