Hi all,
After installing diversion standard on my RT-AX3000 (same as RT-AX58U), I see the following logged every 20mins.
Diversion seems to be working fine.
I don't get this issue if i install 'diversion lite' so i'm guessing it might be related to pixelserv?
Can anyone help with this?
thanks in advance.
Nov 18 12:49:23 kernel: CPU: 1 PID: 21730 Comm: dcd Tainted: P O 4.1.52 #1
Nov 18 12:49:23 kernel: Hardware name: Generic DT based system
Nov 18 12:49:23 kernel: task: d2aa0400 ti: cbe1a000 task.ti: cbe1a000
Nov 18 12:49:23 kernel: PC is at 0xb6c1e39c
Nov 18 12:49:23 kernel: LR is at 0x1dd14
Nov 18 12:49:23 kernel: pc : [<b6c1e39c>] lr : [<0001dd14>] psr: 600f0010
Nov 18 12:49:23 kernel: sp : bed91908 ip : 000a2050 fp : b5eff024
Nov 18 12:49:23 kernel: r10: 000a23c4 r9 : b5eff95c r8 : 000a287c
Nov 18 12:49:23 kernel: r7 : b5eff994 r6 : 000a2876 r5 : 00000000 r4 : b5eff940
Nov 18 12:49:23 kernel: r3 : 00000000 r2 : bed918e4 r1 : 0007d612 r0 : 00000000
Nov 18 12:49:23 kernel: Flags: nZCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
Nov 18 12:49:23 kernel: Control: 10c5387d Table: 0f49804a DAC: 00000015
Nov 18 12:49:23 kernel: [<c0026e60>] (unwind_backtrace) from [<c0022c38>] (show_stack+0x10/0x14)
Nov 18 12:49:23 kernel: [<c0022c38>] (show_stack) from [<c045237c>] (dump_stack+0x8c/0xa0)
Nov 18 12:49:23 kernel: [<c045237c>] (dump_stack) from [<c003aad4>] (get_signal+0x490/0x558)
Nov 18 12:49:23 kernel: [<c003aad4>] (get_signal) from [<c00221d0>] (do_signal+0xc8/0x3ac)
Nov 18 12:49:23 kernel: [<c00221d0>] (do_signal) from [<c0022658>] (do_work_pending+0x94/0xa4)
Nov 18 12:49:23 kernel: [<c0022658>] (do_work_pending) from [<c001f4cc>] (work_pending+0xc/0x20
thanks in advance.
