Creating a VPN network using VPS and RT-AX68U
Now my VPS looks like this:
I get this error:
If you run VPN - WireGuard Client before this, there is no error
It needs to be executed when wgc1 are running for it to work. Infact it needs to be executed every time wgc1 start or restarts.
To be able to do this, we use the hook-file in the router fw:
nano /jffs/scripts/wgclient-start
Put command there:
#!/bin/sh
wg set wgc1 listen-port 51819
Save and exit
Make it executable:
chmod +x /jffs/scripts/wgclient-start
now everything should be set for automatically applied everything for all events.
