crontab using cru -not working
chandras002
Dear all,
last few days, struggling on this...:rolleyes: i want to run tcpdump for every 1 hours using crontab on my Asus merlin - AC88U - firmware 380.65_4. Now testing for every 1 min
so,
1) I have a script name admin.sh : /jffs/scripts/admin.sh
!/bin/sh
echo This is test script running
tcpdump -w a1.pcap -i eth0 -s 65535
Make it executable and it works interactively from command line (creates .pcap file )
2) services-start on jffs/scripts - has following code
#!/bin/sh
sleep 20
/opt/etc/init.d/rc.unslung start
/usr/sbin/cru  a TCPdump2 "*/1 * * * * /jffs/scripts/sh admin.sh"
# enable the  following seems no effect
#cp /jffs/configs/cron /var/spool/cron/crontabs/admin
3) on Router, permission enable to run jffs scripts
What is happening? I can not see a1.pcap file on /jffs/scripts folder.
on System log, i can see the following
rond[538]: USER admin pid 1656 cmd /jffs/scripts/sh admin.sh
Apr  1 18:55:01 cron[1660]: (admin) CMD (/opt/bin/run-parts /opt/etc/cron.5mins^I)
Apr  1 18:55:01 cron[1661]: (admin) CMD (/opt/bin/run-parts /opt/etc/cron.1min^I
4) Output of cru l
admin@RT-AC88U-1D88:/jffs/scripts# cru l
*/1 * * * * /jffs/scripts/sh admin.sh #TCPdump2#
why i can not see pcap file , if the script is running. :(? please advise ..
>>cru a TCPdump2 "*/1 * * * * /jffs/scripts/sh admin.sh , used sh because i use admin.sh from command line (manually) the script giving ->>-sh: admin.sh: not found error.
seems you got some spaces in your cru line
add that to services-start
cru a TCPdump2 "*/1 * * * * /jffs/scripts/admin.sh"
also make the script executable skip the whole sh stuff in the command else it would be
/bin/sh /path/to/command
so i suggest this instead make it executable
chmod +x /jffs/scripts/admin.sh
try that and see if it works better
!/bin/sh
Most scripts usually have '#!/bin/sh' as the first line! :eek:
This test (non-script version) works for me
cru a TCPdump2  "*/1 * * * *" tcpdump -G 59 -W 1 -w /tmp/a1.pcap -i eth0 -s 65535
cru l
*/1 * * * * tcpdump -G 59 -W 1 -w /tmp/a1.pcap -i eth0 -s 65535 #TCPdump2#
cru l
1 ) It is typo - when typing on the forum . I have checked - the actual file #!/bin/sh
2)
yes. non script version works for me too.. :).. not bad.. after long struggle..Not sure..what is issue of script:confused:
you seemed to have slipped an extra /sh into the path to your admin.sh script
Hi Tomsk, it corrected. it is not typo or mistake. i purposely add -sh because sh admin.sh - executed on command line otherwise, getting error.
Later understand, /bin/sh admin.sh - correct way.
Yes i re-read your original post...... saw you mentioned the reason already.... my bad
2)
Does this script work ? either when executed manually from the command line or via cron?
#!/bin/sh
logger -st "($(basename $0))" "Running....."
HHMM=$(date +"%H%M")
tcpdump -G 59 -W 1 -w /opt/a${HHMM}.pcap -i eth0 -s 65535 2> /dev/null
Dear Marin,
1) I copied the script to admin.sh - run from command line it work :)
2) Later in used cru in services-start
seems it working :). as time stamp based a2252.pacp created. And it's size rolling (changing) and reset every 1 min.
Later find another time stamp pcap file created after 10 minutes. The size is rolling and reset too. Guess, something to do with G flag.
Wonder, what is the problem earlier. Any way, Thanks for your time and efforts! (Thanks all other members too).
This community spirit makes ASUS- Merlin a special. :cool:
Cheers!
chandra
.... Guess, something to do with G flag.
When tcpdump is started, by default (without any 'limiting' flags) it will continuously write to either sysout or the '-w file_name' until the process is physically terminated.
So if you are requesting tcpdump every minute via cru, then the '-G 59 -W 1' flags determines how many seconds the existing tcpdump process will run until it automatically terminates - in this case it will terminate 1 second before the next instance is requested unless you really want several tcpdump processes running concurrently?:D
You can tailor the flags to suit your needs for keeping several generations of the files.
Dear Martin and fellow friends,
Seems still some problem. ;). I am seeing the new pcap file every 10 min, though the cron should be every min interval. After 10 min, new pcap file created and updated.. in the same time, i seeing the previous files also updating...
Please see the attached screenshot. The following should call the admin.sh - every min right. I tried */2 * * * * as well. View attachment 8953
Here is pcap file - which created for every 10 min like 10.44am, 10.54am ....till 11.54am. not sure why the C1144.pcap .
The pcap file take local time -is morning 10 am to 11am...like C1154.pcap.
Cron inside services-start. admin..sh in moved to USB.
So, te main questions - why the previous time -stamped file still updating (increasing the file size)..it should be stopped for every 1 min. Right? :rolleyes:.. Any thoughts highly welcome. Thanks a lot.
Try the modified tcpdump command
https://www.snbforums.com/threads/crontab-using-cru-not-working.38348/#post-316200
The manual (non-script) command that I suggested you try...which you did successfully in post #5
https://www.snbforums.com/threads/crontab-using-cru-not-working.38348/#post-316196
probably dropped the '-W 1' arg in the script?
Here is script... do not see anything strange..following is the current tcpdump command (yes -W 1 dropped - not using -C anymore )
tcpdump -w /tmp/mnt/ex2/entware-ng.arm/C${HHMM}.pcap -i eth0 -s 65535 host 66.96.199.138
Am I missing?
yes, #5 post, worked.. technically correct. but the i am getting all the previous time stamped files too updating..either for 5 min or 1 hours... that is confusing.:rolleyes:
tcpdump -w /tmp/mnt/ex2/entware-ng.arm/C${HHMM}.pcap -i eth0 -s 65535 host 66.96.199.138.:rolleyes:
FFS - RTFM!!! :mad:
Without the 'G xx -W 1' parms or 'C xxxx' etc. using your command syntax (above), an executing instance of tcpdump will continue to run until it either is manually terminated or will recycle a file based on size etc.
However, if you manually issue
tcpdump -G 59 -W 1 -w /opt/CAAAA.pcap -i eth0 -s 65535 &
then wait 10 seconds and issue
tcpdump -G 59 -W 1 -w /opt/CBBBB.pcap -i eth0 -s 65535 &
ps | grep tcpdump | grep -v "grep tcpdump" | wc -l
there should be 2 reported instances of tcpdump running...writing to
CAAAA.pcap and CBBBB.pcap
If you now wait a further 60 seconds, both instances will issue message:
Maximum file limit reached: 1
stating that they have automatically terminated (due to the ' -G 59 -W 1' parameters) and command
should report 0.
If the cru schedule is incorrect then it may contribute to the timestamp issues etc., but I suspect it is lack of reading the tcpdump man pages that is causing the real issue.
Good luck.
Dear Martin, Thank for kindness..:). I take it in right spirit....
yes my friend too said "read the Man page". I go through the details and nitty-gritty & post it here. (for the other forum readers):cool:
I am having a similar issue with this script:
#!/bin/sh
cru a malware-filter "0 */12 *** /jffs/scripts/malware-filter"
When I type cru l. it shows the job is loaded, but it does not run!
Could this be a cron issue or is it a script error?
Use:
cru a malware-filter "0 */12 * * * /jffs/scripts/malware-filter"
If you have .sh at end
cru a malware-filter "0 */12 * * * /jffs/scripts/malware-filter.sh"
@Csection
If you use this, you have to have .sh then end of file.
#!/bin/sh
sh /jffs/scripts/malware-filter.sh
