crontab using cru -not working
You have it under: /jffs/scripts/firewall-start
And enabled: Enable JFFS custom scripts and configs?
#!/bin/sh
sh /jffs/scripts/malware-filter.sh
From command line do, and test again: dos2unix /jffs/scripts/firewall-start
#!/bin/sh
I have firewall-start under /jffs.
Should it be in /jffs/scripts?
Beware that there is an Exit 0 in the cru script..
So if you call it from another script, say services-start , it will close THAT script too, unless you take precautions, like starting it with an sh...
Not true.
YOU ARE RIGHT! I tried a test case and found out that the exit does not cause the termination of the caller.. I suspect if "source" or something else is used then it might kill the caller..
