Voxel Custom firmware build for Orbi RBK50/RBK53 (RBR50, RBS50) v. 9.2.5.2.34SF-HW
How exactly did you change location? I am having the same issue tried different browser no luck? Thanks
I went to a friend’s house and download from there. He lives one town over. I also tried downloading over mobile and that works too.
In screen shot, the ones that are not connected are rbs10 the other that is connected rbs50. I am guessing because rbs10 has orbi fw and rbr50 and rbs50 has Voxel?
I can't tell you exactly and check as I don't have any RBS10 devices. You can check it yourself if you want by installing the stock firmware on the RBR50.
All I know is that RBS50 can be freely connected to LBR20.
Voxel.
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-v-2-5-0-42sf-hw.60308/
https://www.snbforums.com/threads/c...50-rbk53-rbr50-rbs50-v-9-2-5-2-32sf-hw.88717/
https://www.snbforums.com/threads/c...50-rbk53-rbr50-rbs50-v-9-2-5-2-33sf-hw.89630/
New version of my custom firmware build: 9.2.5.2.34SF-HW.
Changes (vs 9.2.5.2.33SF-HW):
1. Toolchain: Go is upgraded 1.22.2->1.22.3.
2. unbound package (used in stubby) is upgraded 1.19.3->1.20.0 (fixing CVE-2024-33655).
(score 3.7, Low)​
3. lighttpd package is upgraded 1.4.75->1.4.76 (to avoid CVE-2024-3094 xz supply chain attack).
(score 10.0, Critical, but most likely does not apply to this ORBI firmware version)​
4. OpenSSL v. 1.1.1 package is upgraded to OpenSSL v. 3.0.x 1.1.1w->3.0.13.
5. dropbear package is upgraded 2024.84->2024.85.
6. e2fsprogs package is upgraded 1.47.0->1.47.1.
7. bind package is upgraded 9.18.25->9.18.27.
8. nghttp2 package is upgraded 1.61.0->1.62.1.
9. curl package is upgraded 8.7.1->8.8.0.
10. nano package is upgraded 7.2->8.0.
11. iperf3 package is upgraded 3.16->3.17.1.
12. iw package is upgraded 6.7->6.9.
13. Upgrade pcre 8.45 to pcre2 10.43 8.45->10.43.
14. ngrep: disable pcre.
15. wget: replace dependence on pcre with dependence on pcre2.
16. samba36: add patch to undef 'mkdir' macro.
17. hotplug2: fix hotplug2.mount script (minor missprint).
18. OpenVPN: add NG/DNI patches for system logs.
19. Host tools: upgrade e2fsprogs to 1.47.1.
20. Host tools: upgrade UPX to 4.2.4.
NOTE:
The most important change in this release is an update of OpenSSL v. 1.1.1 to OpenSSL v. 3.0.x.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Voxel:
Thank you for your hard work in continuing these firmware releases. As others have mentioned there seems to be an issue downloading this release from particular isp's. Never had an issue before. Any thoughts? Thanks again.
Voxel:
I can't say for sure, my hosting is in Lithuania (thanks to vladlenas). I'm in another country and I have no problem accessing the server. In any case, I can't influence it. Probably temporary issue.
Voxel
