Custom firmware build for R9000 v. 1.0.4.27HF/1.0.4.27HF-HW
I never used this function before, but I tried it and I'm having the same issue as you. Netgear recently released stock 1.0.4.28 and that worked fine, so you're gonna have to ask @Voxel about what changes he did from stock to this.
Thanks for you report. Of course I have the plans to include latest stock changes into next release.
Voxel.
@Voxel what version of igmpproxy comes with Entware tools? is the same like this link https://github.com/pali/igmpproxy/releases ?
If so, does this version supports IGMP v3?
thanks in advance for your reply
I really do not know all the packages in Entware. Regarding concrete igmpproxy from Entware, its version is 0.2.1 i.e. latest. But I am not aware any specific of this package, like IGMP v3, sorry. If latest official version supports it then yes.
Entware package list:
https://voxel-firmware.com/Downloads/Voxel/html/entware.html
so from there:
igmpproxy 0.2.1-4 net IGMPproxy is a simple dynamic Multicast Routing Daemon using only IGMP signalling (Internet Group Management Protocol).
Voxel.
Dear Voxel
Are there any default scripts to reset and rewrite on crontab? After I edited crontab, it works fine. Days or weeks later, when I check crontab, it come back to original scripts.
like
0 2 * * * 11k_scan &
12 03 * * * /TM/QoSControl auto_update
*/10 * * * * sync; echo 3 > /proc/sys/vm/drop_caches
Do you have any idea why scripts come back to original one? Which task we should keep in crontab? Thanks in advance.
Dear Voxel
like
Use your own cronjob since Netgear restart/reset the ordinary one sometimes.
Look here for examples:
https://www.snbforums.com/threads/h...ile-with-dnscrypt-proxy-v2.49803/#post-446156
https://www.snbforums.com/threads/s...ther-log-related-questions.49535/#post-442575
You have to setup ssh access by authorization keys. Current settings of dropbear do no allow entering by the password. See Appendix A in my README.
No, it is not normal. setting dnscryptproxy2 to 0 should work. Check it by
nvram get  dnscrypt2
after reboot. It works in my R9000.
Voxel.
Thanks for your reply Voxel.
You are absolutely right, all the instructions to set SSH access are at Readme file on your web site.
Regarding to how to disable DNSCrypt, I tried to do by setting it to "0" as I mentioned before, but still was enable after rebooting.
Only way I found to completely disable was doing "/etc/init.d/dnscrypt-proxy-2 stop" and then "/etc/init.d/dnscrypt-proxy-2 disable".
No problem for me to do that, but maybe I can help you by fixing an issue that might be present somewhere ?
Cheers, A.
It just cannot be. I checked again. Loot at the part of code for dnscrypt-2 init script:
CONFIG=/bin/config
DNSCRYPTPROXY2_ON=$($CONFIG get dnscrypt2)
start() {
    # Check if dnscrypt-proxy-2 is enabled
    if [ ! "$DNSCRYPTPROXY2_ON" == "1" ]; then
        echo "DNSCrypt-Proxy-2 is not enabled in nvram. Exit."
        exit 1
    fi
So if it is is not set as "1" in nvram script stops running.
Maybe you did some typo misprint? Not "set dnscrypt2=1"?
Check this:
nvram show | grep dnscrypt
Voxel.
Maybe you are both right, but using different words for same thing? :)
  • Daemon Enabled:
    (The scripts in /etc/init.d/ directory are used to start, stop, or restart the Linux system daemons.
    To be started it must first be enabled)
    /etc/init.d/dnscrypt-proxy-2 enabled && echo ENABLED || echo DISABLED
    ENABLED
  • NVRAM Activated:
    [ "$(nvram get dnscrypt2)" = "1" ] && echo ACTIVATED || echo NOT ACTIVATED
    ACTIVATED
  • Process Running/Started/Active:
    ps | grep -v grep | grep dnscrypt-proxy-2 >/dev/null && echo RUNNING || echo NOT RUNNING
    RUNNING
CONFIG=/bin/config
start() {
        exit 1
    fi
Check this:
Voxel.
  • Daemon Enabled:
This daemon is enabled by default I mean. And the commands nvram set dnscrypt2=0; nvram commit should disable dnscrypt-proxy-2 startup. So I do not see an issue with this,,,
Voxel.
