Custom scripts dont start when reboot the router
Edit:
But when i run "touch /tmp/@@@services-start"
I see still nothing
This does not generate any output, all it does is create an empty file in /tmp/ .
Ok it is there but what is the sense of it?
You put it inside the script you need to test. That way, you can tell if the script actually ran or not by looking for the presence of that file in /tmp .
AH, got it.
Wil add the line.
Just upgrades tot the latest version.
Good work and support.
Tomato works fine but the Galaxy s4 from my son got a lot of disconnects.
My s4 works fine also all other devices.
Therefore back tot Merlins firmware.
But also the wifi works beter with merlin then tomato.
Again tnx
Hello:
I am suffering this problems against mi RT-AC88U. Excuse my english.
There are no panels to activate "jffs" and they are activated for ever. I put mi scripts under /jffs/scripts and even they executed OK directly, they don't exec at the startup.
I have found another solution having permanently connect and USB:
USING NVRAM to configure parameter "script_usbmount"
Command... nvram show 2>&1 | grep script_usbmount
returns... script_usbmount=
Command ... nvram set script_usbmount="/jffs/scripts/xxx.sh"
Command... nvram commit
returns... script_usbmount=/jffs/scripts/xxx.sh
Whit this, the script xxx.sh is effectively execute at startup if they arre a pendrive inserted in USB port
I suppose that another variable of NVRAM could exec an script without pendrive inserted, but I don't know wich
Hello:
What firmware version?
I am sorry, I have noticed that it is a threath for MERLIN firmware and I have the official firmware ( 3.0.0.4.380_7266-g6439257).
I am thinkig into install MERLIN but ...
Thanks a lot
That's your problem then. JFFS custom scripts is a feature specific to my firmware.
