Thread necromancy time.
http://forums.smallnetbuilder.com/showpost.php?p=5609&postcount=47
^^ This issue has basically never gone away.
DGL 4500 and DWA 160 Rev. B, latest firmwares across the boards.
Same physical situation: Seperated by two floors, etc. etc.
Most of the time DWA 160 functions well and gets very nice speeds and performance but we just know we can count on occasional, intermittent drop outs and I want to see what I can do help this situation out.
Unfortunately, moving that second machine with the DWA 160 closer to the router is not feasible currently nor is any hard wired situation.
My current DGL 4500 wireless settings are:
Overall, I'm very satisfied with this equipment. This isn't the end of the world but I'd like to see what I can do to get rid of this little problem, if possible.
Thanks again as always! I lurk a lot more than I post but I view this entire site as invaluable and I assure you I've spread the word to many others.
2.4 GHZ (better range than 5GHz)
802.11n only
Enable Auto channel scan On
Transmission Rate: "Best Automatic"
Channel width: 40MHz (should this be 20/40 auto instead? )
Security mode: WPA-Personal
WPA 2 Only
AES Ciper
Group Key update interval: 3600
