/data/.kernel_nvram.setting not editable on GT-AXE11000
ckcameron
Community and @RMerlin
I am running a GT-AXE11000 on 388.2_2 and I am receiving an error when I attempt to commit the nvram.
"copy_file:217 Could not open file:/data/.kernel_nvram.setting"
I cannot alter this file because the directory sits on a read-only partition, but neither can my nvram binary.
Thoughts?
Best,
CK
Welcome to the forums @ckcameron.
What is the actual command you're trying to use?
Obvious question - have you rebooted the router?
Have you tried any other firmware version, either stock Asus or older Merlin?
I am having this exact same issue. Same router.
Problem SEEMS to go away with factory firmware Going to try older merlin firmwares and see if any do anything to help.
