dd-wrt for RT-AC87R
Still having the 5G issue. :mad:
Have you tried 378.52_alpha3? My 5GHz band has been fine but It has also never been an issue for me. In fact, the 2.4GHz band has been much more problematic for me than the 5GHz band.
So I gave DD-WRT version r26446 a 4 day trial and it kept dropping the 2.4GHz band altogether after 18-24 hours of uptime. I tried a daily reboot at 5:30am, a nice feature Brainslayer has built into DD-WRT's GUI, in order to see wther or not a fresh boot each day would resolve this issue (it had absolutely no effect AFAICT). The only way I could "regain" the 2.4GHz band was to do a factory reset and MANUALLY reenter all of my configuration settings (no fun son).
Upon the 2.4GHz band failing for the 3rd time in as many days I went back to Merlin. While 378.52_alpha3 has been a little wonky from time to time my solution has sorted it out. That is to use the WPS button method to erase the nvram (please search the FAQ and this forum before asking how to do so), put the router into recovery mode and then reflash the router using the Asus firmware recovery utility.
Of course, I did a backup of the router's configuration settings with the fantastic utility that John9527 has been kind enough to make available (we're not worthy). This way, after reflashing the router, a few keystrokes restores your settings with the exception of any closed-source stuff. So you still have to manually reenter those settings but that is a piece of cake as compared to having to manually reenter all of your settings as we had to do before the wonderful nvram save & restore utility from John9527.
You using it? hows wifi?
I think I may go back , I had one hell of a time this morning with ios and wifi in the one I posted above.
I also purchased a NAS today (on sale amazon) I am tired of the stutter from movie playback thru the router.
EDIT: I just switched back, trying dd-wrt now, wifi on the other merlin alfa 3 just went to sh!!.
Most likely due to the reboot of the router I did last night that so far not any firmware has passed with this router.
I am about to flash, how is it? DDRT always seems faster than the Stock firmware.
Give me your thoughts. Also if I am not mistaken you can control the signal strength
with DDWRT where in Stock firmware it is locked at 80 max.
CC
Give this new version of DDWRT a try, it is getting good reviews,
CC
Since 2446 here are the fixes to date:
==> 26622 --- 2015/03/31 -------------------------------------------------------------------------------
[26618-26619] Update: Kernel 4.0-rc6
[26588-26590,26595-26601] Fix: Remove unnecessary code for hostapd
[26602-26603] Fix: SSL buffer implementation
[26604-26615] Fix: Network interface label
[26616] Fix: IPv6/radvd http://svn.dd-wrt.com/ticket/4022
==> 26587 --- 2015/03/27 -------------------------------------------------------------------------------
[26514-26515,26559-26560,26587] Update: Kernel 3.10.73, 3.18.10, 3.19.3, 4.0-rc5
[26491-26494] Update: OpenSSL 1.0.2a
[26525-26526] Update: DNSMasq 2.73rc1 http://svn.dd-wrt.com/ticket/3847
[26528-26529] Update: libpcap 1.8.0
[26527] Update: BusyBox 1.23.2
[26519-26524] Fix: [Broadcom] Timer issue
[26538-26539] Fix: NAT rules broken for PPTP/PPPoE dual WAN connection http://svn.dd-wrt.com/ticket/4033
[26564-26586] Fix: SSL memory leaks + Enhancements
[26508-26510] Add: Network stack offload using multiple cores
[26511-26513] Add: PPTP acceleration
[26534-26535] Add: DIR-860L A1 support
[26536-26537] Add: New chipset support
[26530] Add: php5 curl support
[26558] Add: Display VHT capabilities if available
[26543-26556,26562-26563] Add: DIR-859 A1 and QCA956x support
==> 26490 --- 2015/03/19 -------------------------------------------------------------------------------
[26452,26474-26476,26488] Update: Kernel 3.2.68, 3.10.72, 3.18.9, 3.19.2, 4.0-rc4
[26477-26479] Update: Quagga 0.99.24
[26448-26449] Fix: VAPs on triple radio
[26450-26451] SemiFix: Repeater Bridge broken for k2.6 and k3.x http://svn.dd-wrt.com/ticket/4038
[26469,26484-26485] SemiFix: PPTP http://svn.dd-wrt.com/ticket/3280
[26467-26473,26489-26490] Fix: L2TP http://svn.dd-wrt.com/ticket/4043
[26462-26463] Add: L2TP MPPE encryption support
[26480-26483] Add: User customizable config for wireless security
[26486-26487] Add: Octeon MMC support
[26464] Add: WR740NDv5 support http://svn.dd-wrt.com/ticket/4035
CC
CC
Yes you are write , dd-wrt does have lots of control and does work well.
Yes you can control the signal.
Time will tell
Time will tell
The one post on this new version reminded me of your situation:
"Working really well as a client bridge for me thus far. Streaming music from my NAS and browsing with no issues."
CC
CC
Actually, I am going to stay with 378.52_alpha3 for a while. it has been remarkably steady for me thus far. DD-WRT is a wonderful firmware but if it ain't broke (and it is not broke right now) don't fix it, right?
Edit: Okay I lied. I went up to Asus 378_4839 and all seems well, so far.
Can you put feedback on issues you had on the PS4 Lag thread, or the alpha3 thread so that others can see ? I havent had any wifi issues at all on the alpha3
Cheers
Time will tell
Tried the latest DDWRT release. The usual lightning fast page reloads. After an hour the router crashed. Rebooted. Then lost 5 ghz signal after about a half hour. The HD connected to USB did not show in the network. Seems that the 2446 release was the best so far.
Now flashed the RT-AC87U_3.0.0.4_378_4839 latest beta Stock from Asus. Running perfectly. USB wireless file transfers are lightening fast. Very impressed.
CC
CC
Hmm , I don't seem to have any problem with the latest dd-wrt, that is strange..... (I'll test more tonight)
You did reset and clear nvram?
I am getting a NAS to get my usb off the router (I am not happy about spending what I did, this router for the price should work perfectly, but obviously has flawy.
They just released a new version.
ftp://ftp.dd-wrt.com/betas/2015/04-01-2015-r26635/asus-rt-ac87u/
How long have you had it up for?
CC
CC
OH, thats why, I am on 1-31-2015 version, maybe the one of 4-1-2015 is an April fools joke??
that would explain why the problems?
EDIT : 3-31-2015 not the one above.
Whats the release number? There is no 1/31 release?
CC
Tonight I had problems with dd-wrt and wifi on my iPhone 6+.
yes same as yesterday with alfa3
So I pulled power to the router for over 5 minutes also cable modem , why not .. Also to note this is my first power down in a long time.
All is good now after power up
This just goes to show something is screwy with this router, wifi, and reboots. I will go back to the Alfa 3 soon , now that I know it's most likly the router and reboots doing it. I just need to power off for 5+ minutes.
You have to try RT-AC87U_3.0.0.4_378_4839 latest beta Stock from Asus. I think this may be your answer. The wifi signal strength is superb and rock solid. Also is my 2 TB HD streaming as well as Netflix etc...
Defran1 give this a shot first.
http://goo.gl/6wm8E1
CC
Looks like a newer beta Now
RT-AC87U_3.0.0.4_378_4950 - Unofficial beta firmware
it's official now (4950), no more beta...
- wan download speed 934Mbs (speedtest.net)
- lan to wifi - 410Mbs (on galaxy s5)
-wifi to synology NAS - 380Mbs
- pc <-> synology NAS,, (windows 8.1 copy test 2Gb file) - 115MBs - cat6 cable
- real download using buildin synology download client - max 42MBs
No more 5Ghz disconnects on my 2 iphones (5 and 5S) and ipad retina. In fact i have no disconnects at all on 5Ghz.
Those are my test cases until now with the official 4950,
Please share yours.
Please share yours.
This firmware is great. Here are the speedtest results from my Surface Pro 3 surfing wirelessly on my patio about 40 feet from the router (through 3 walls and my fireplace no less). Amazing!
So noob here, but I've done all the settings like they have listed above but I guess I'm not following exactly how to fix the PS4 lag. What did you do?
Γ RT-AC87R no more 2.4GHz signal! ASUS AC Routers & Adapters (Wi-Fi 5) 2
